The Official Mk7 Wheel Thread
This is a sticky topic.
Originally posted by avdo_ View PostYou might be too close to the strut as you're going around 12.7mm wider on the inner and outer of the wheel.
I think you'd need to be more like ET40, which is probably more common to in x 9 wheels, but you're then at 25mm poke on a GTI which will definitely require work on the front, and probably the rear as well.
There are cars running as aggressively as that on this thread, just need to invest to make it work.
(Note I know you're not in a GTI but my visuals/measurements are based on my own car so I find it helps me to reference back to that)
Damn i've just jumped the gun.....Bid and won on 5 x genuine Audi rotor wheels... $1200 for the lot. Pretty good considering they go for $1800 each from AudiPAST: 88' Mk2 Golf 16v GTI & 97' Mk3 Golf VR6
CURRENT: 13' Mk7 Golf 103 TSI Highline
I was going to ask if they were Audi wheels, some of the few that have the high offset.
Can always try a test fit given you've already 'got them' but I reckon there will be clearance issues.
On the plus side it shouldn't be hard to get your money back on them in a resale.
Per the discussion last week ( http://www.vwwatercooled.com/forums/...ml#post1072376 ) on Omanyts, here is a car running 19 inch dark charcoal/grey reps of unknown specification:
Thought i'd ask on here again...... 18" x 7.5" et45 will this work with a 35mm drop without any rub issues to the outside of the arches? I'm thinking this should be more than ok but would like to double check.
Thanks.PAST: 88' Mk2 Golf 16v GTI & 97' Mk3 Golf VR6
Originally posted by Wezza View PostThought i'd ask on here again...... 18" x 7.5" et45 will this work with a 35mm drop without any rub issues to the outside of the arches? I'm thinking this should be more than ok but would like to double check.
Originally posted by Dutch77 View PostAUDI S LINE 9 SPOKE
Specs: 20 x 8.5 (f) 20 x 9 (r), ET45 (f) ET46 (r), weight 29lbs/13.1kg
[ATTACH=CONFIG]10974[/ATTACH]
[ATTACH=CONFIG]10975[/ATTACH]
[ATTACH=CONFIG]10976[/ATTACH]
Note these wheels have been powder coated black, think of them in silver and they will appear more familiar.2018 Golf 7.5 110TSi Comfortline | Drivers Assistance Package | Retrofitted: Traffic Jam Assist | Emergency Assist II | Light Assist | OEM Vienna Leather Sports Seats with full Highline Interior | Power Folding Mirrors
Originally posted by Wezza View Post^ Cheers Dutch. Looking at a few different options now. But pays to be certain rather than buy another set of wheels that might not fitOn another note, if i was to buy rims from a 4x4 (I'm looking at OEM Amarok 'Durban' wheels) would they be heavier than VW Golf wheels or about the same?
[ATTACH=CONFIG]11037[/ATTACH]
They are a lot heavier as they have to support the load rating of the ute (2.5 Tonne i believe)
Guy from APR weighed his stock amarok wheels with tyres at 35-40kg per corner.
