GTI - PP: 1. The mechanical haldex e-diff will definitely be better than the XDL electronic only pseudo diff. XDL brakes the inside wheel, in effect slowing that side of the vehicle down at slower speeds imo. E-Diff would speed things up. 2. E-diff as a stand alone option for 980GBP / $1500 AUD is a no brainer. Issues are:
GTI - PP is one to get if you drive tight twisties like Macquarie Pass South of Sydney very often and perhaps give greater traction from stationary take off. Most owners that want the ultimate in grip from stationary position usually go for the Golf R, which is better again in that regard for probably not a lot more than the GTI - PP. The GTI - PP is bound to have a lower CoG at the front end with the motor sitting lower -v- Golf R AWD. The Man-Trans std GTI wins out in respect to weight being the antithesis of sports car handling. 45kgs removed from the front end, where you don't want it in a FWD, will make the MT Std GTI a more flowing vehicle to drive from corner to corner in the medium to faster flowing b-grade routes (not super tight & twisting canyons/mountain roads), as long as your driving up to 8/10ths. Any more than that and the XDL at lower speeds can be disruptive and annoying at times, as it FWD. Higher speeds where XDL just lightly taps the brakes for improved turn-in works for both std and PP GTI's, but with the std GTI having 45kgs less to point into the corner. Neither does the Audi S3 nor Golf 7 R have the PP's e-diff, but do have XDL. Personally ... I would've gone for the GTI - PP as a stand alone option for $1500 with Man Trans. For about 6K premium with all the other bells and whistles is not something I would have added to the GTI - PP. Irony of the matter is that the GTI - PP would give better traction and motion from 8/10ths - 10/10ths ... but the GTI always has been and always will be an 8-9/10ths vehicle. For that final tenth to 10/10ths ... better look elsewhere like RS265 or BRZ/FT86 or BMW 1 series.
WJ
WJ
