VCDS (VAG-COM) codes and programmable options for Golf Mk7
  • ^^^^ See response to Jonoz question in thread "Disable Stop/start - VCDS tweak" here
    • Thanks alanzidane for bringing this all together,
      Has anyone found the coding for this one? I'm keen to try it.
      Cheers!
      Originally posted by alanzidane View Post
      9. Full brake light if you have LED tail light(GTI Performance OR R)
      I lost the screen shot to show your guys. Here is the photos to compare before and after. I'll post the screen shot later on.
      CR Audi RS3
      PW Golf 7 GTI
      • Is there a way to program the indicators to flash four times instead of three for when you tap the stalk?
        MY16 MK7 Golf GTI
        - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
        • Originally posted by Ralfi View Post
          Ralfi: yes, my VCDS tweak instructions are HERE
          • Originally posted by 2muchcoffeeman View Post
            Cheers!
            2MuchCoffeeMan do you mean this? (for the inner tail lights to work as brake lights as well)
            Activation of the tail light brake light
            The inner taillights are also activated during braking.
            1. Select STG 09 (vehicle power)
            2. STG Security Function 16
            3. Enter access code 31347
            4. Channel (8 )-Leuchte27 NSL RC6-Lichtfunktion C27
            5. Set to brake light - Bremslicht (default: nicht aktiv)
            6. Channel (10)-Leuchte27 NSL RC6-Dimming CD27
            7. Set to 100 Set(default: 0)
            • Originally posted by TJG View Post
              Perfect! Many thanks!
              CR Audi RS3
              PW Golf 7 GTI
              • I found this one on another forum. Sounds like it might work as well?
                9- Central Electronics
                16- Security Access
                10- Adaptations
                Left Inner Tail light functions as runner/brake/ signal.
                8 leuchte23sl HLC10-Lichtfunktion C23
                Brake Light
                9 leuchte23 sl hlc10 - Lichtfunction D 23
                Blinken Links Hellphase
                10 leuchte23sl hcl10 - dimmwert CD 23
                100
                Allows Left Signal to "overpower" Running light and brake Light.
                12 leuchte23sl hlc10-lichtfunktion E 23
                Blinken Links Dunkelphase
                14 leuchte23sl hcl10-dimmwert EF 23
                0
                15 leuchte23sl hlc10-dimming direction EF 23
                Minimize
                Right Inner Tail light functions as runner/brake/ signal
                8 leuchte24sl HRA65-Lichtfunktion C24
                Brake Light
                9 leuchte24sl HRA65 - Lichtfunction D 24
                Blinken Rechts Hellphase
                10 leuchte24sl HRA65 - dimmwert CD 24
                100
                Allows Right Signal to "overpower" Running light and brake Light.
                12 leuchte24sl HRA65-lichtfunktion E 24
                Blinken Rechts Dunkelphase
                14 leuchte24sl HRA65-dimmwert EF 24
                0
                15-Leuchte24SL HRA65-Dimming Direction EF 24
                Minimize
                Left Signal completely goes out between blinks.
                16 - leuchte20BR LA71-Lichtefunktion G 20
                19 - leuchte20BR LA71-dimming Direction GH 20
                Minimize
                Right Signal completely goes out between blinks.
                16 - leuchte21BR RC8-Lichtefunktion G 21
                19 - leuchte21BR RC8-dimming Direction GH 21
                Minimize
                CR Audi RS3
                PW Golf 7 GTI
                • Anyone in Brisbane with a VCDS that can help me turn down my soundaktor? I'm on the north side at alderley but happy to drive to you. Cheers!
                  • Originally posted by Boon View Post
                    Can Do (Albany Creek) - PM me if your interested.
                      16- Security Access
                      10- Adaptations
                      Brake Light
                      100
                      0
                      Minimize
                      Brake Light
                      100
                      0
                      Minimize
                      Minimize
                      Minimize
                      Think this might be for US where they can use brake lights also as indicators. Looks like this might blink your brake/tail lights with your indicators. Not really sure though.
                      • Good point!
                        Might just go vanilla
                        CR Audi RS3
                        PW Golf 7 GTI
                          TJG: The tweak instructions were originally developed by Jeremy Bale (handle "JBale") on VWVortex site in September last year. JBale has a NAR model mk7. Here's the link to JBale's post which contains a graphic together with a video of what the tweak
                          VWVortex.com - VAGCOM - What is this and how do I do it? (new to VW)
                            TJG: The tweak instructions were originally developed by Jeremy Bale (handle "JBale") on VWVortex site in September last year. JBale has a NAR model mk7. Here's the link to JBale's post which contains a graphic together with a video of what the tweak does
                            • Originally posted by DV52 View Post
                              Thanks DV52
                              Blinks brake/tail lights including inners with/as indicators for US.
                              Would I be correct in assuming from the graphic that the US models do not actually have amber indicators integrated into their light clusters and they rely completely on the flashing of the brake/tail light ?
                                Thanks DV52
                                TJG: Yes, that's my understanding although I have to say that I find the DOT rules in the US to be unfathomable (not that our own ADRs are any easier to read)!.
                                I also understand that the NAR model mk7 also have "side marker" lights which also flash as a turn indicator (I think DOT allows these to be either synchronous, or asynchronous with the tail-light turn signal)
