Due to the type of problem that this is, there would have been quite a few engines with physical damage but which are still running "fine". The update resolves the issue which was causing the physical damage to the engines, but it obviously can't fix any damage which already occurred. This damage can eventually lead to loss of compression in a cylinder as anders has noted.
But as I said, there hasn't been a single report (that anyone from this forum is aware of) of an engine manufactured since 24S4 having a failure (or for that matter, manufacturered slightly before but flashed immediately on arrival to the country and before being driven with local fuel).
So yeah, anything manufactured since June 2010 should be fine.
