Originally posted by MkVIGTI
View Post
MDI niggles
website: www.my-gti.com
Re: MDI niggles
Originally posted by Maverick
Who would have thought that a lossless format like CD would be better than an icrud playing back a lossy format.
CD's will always sound the best but lossless is very close and the mdi sounds fairly good. Also on the stock speakers/amp you can't tell a huge difference.
Lets hope VW bring out a new firmware for the MDI soon.Last edited by G-rig; 16-04-2010, 05:52 AM.
Re: MDI niggles
Originally posted by coreyingLol... only an Apple user could say a comment like that seriously!
You do realise the big issue with that comment right?
They should sound the same minus any loss through the mdi cable etc.
I use flac at home on the pc with Foobar and that is just as good, so are wav files.
That's what I'm trying to say. There should be NO difference between a lossless file and the original source.
If there is, then the 'CD ripping' stage hasn't done it's job properly, or the playback chain is not up to scratch. Obviously Apple being Apple, and forcing users to only be able to hear their digital music via analogue output is the cause here
Originally posted by G-rig View PostHow do you know he wasn't playing low bitrate mp3 on the phone?
Especially when the CD which is lossless is being played goes from a digital source to the headunit as a digital signal and is only converted to analog at the speakers whereas the icrud plays a lossy digital file converts it to analog is transmitted to the MDI and passed through to the headunit (I'm not sure if the signal is converted back to digital and finally back to analog at the speaker outputs at this stage).
Also on the stock speakers/amp you can't tell a huge difference.website: www.my-gti.com
Originally posted by Maverick View PostIt's irrelevant as it's a lossy format.
But it's still not the same, being surprised that a lossless format sounds better than a lossy format is like being surprised that the sky is blue.
Clean out your ears!
My point is that most people may not hear the difference on the stock sound system between mp3 and lossless, however the better speakers/sound system the more you'll hear inaccuracies in low quality music rips/bitrates.
Originally posted by G-rig View PostWe are all basically saying the same thing..
My point is that most people may not hear the difference on the stock sound system between mp3 and lossless, however the better speakers/sound system the more you'll hear inaccuracies in low quality music rips/bitrates.website: www.my-gti.com
Originally posted by Maverick View PostExcept you're doing the faithful Apple Fanboi argument and skirting around the fact that a lossy format (whether it be on an Apple Icrud or not) is inferior to a lossless format, personally I don't care as high quality MP3's are good enough given all the limitations with audio in the car.
I don't particularly like apple or itunes or apple lossless, but until there are head units out that support FLAC it will have to do, but interfaces with the car pretty well, except for the VW MDI bugs.
You would need ears full of wax to not hear the difference, even between high quality mp3's and a cd source you can hear the difference on the stock system.
Originally posted by G-rig View PostWe are not talking about lossy formats, but apple lossless vs CD.
Apple lossless may be close to CD quality but you forget that it's let down by the icrud that is playing it back. The sound quality will never be as good as a CD player in a head unit or a PC with a digital output to an amp or a CD player connected to an amp.
I can hear the difference but it sounded like you couldn't if you think the stock MK5 setup sounds good. Although i may have got a dud car last time.website: www.my-gti.com
The car environment isn't that bad and the mk6 has better sound deadening as well and is pretty quiet.
I already have a home setup and headphones but see your point.
There is nothing wrong with the iPhone sound quality when using decent quality files, have you tried listening to it with decent headphones?
People don't need to do any mods then.
Ps no one listen to mav as he's got an iPhone himself.
Originally posted by G-rig View PostThe car environment isn't that bad and the mk6 has better sound deadening as well and is pretty quiet.
Ps no one listen to mav as he's got an iPhone himself.website: www.my-gti.com
Originally posted by G-rig View PostThe point is there's not much point using CDs as the vw speakers and head unit/amp aren't of high quality.
You can hear the difference between a CD and a lossless format on the icrud/iturd so how can the stock head unit and amp not be of high enough quality?website: www.my-gti.com
Second point, digital is already a lossy medium. A sine wave has to be sampled considerably more than 44 times a second to give close to a continuous analogue waveform. Since CDs are 44.1Hz you're stuck with a less than perfect medium to begin with. Audiophiles (and gear-snobs too, I suspect) will often refer to 'graininess' in digital recordings due to this. For them it's vinyl or nothing.
Third point, car+driving=noise. It's not the perfect environment for listening to music, so why bother getting all heated up? Listen to the radio if it bothers you that much.MY10 Golf MkVI 103TDI United Grey
