4motion clutch issues
  • 4motion clutch issues
    Yep, exciting times. My 4motion was going just fine for a couple of months,then one day, I thought it slipped when I drove off. About a week later, it started slipping like a b____. So, it is up on jack stands and I am giving it a go myself. It may be an oil seal or the clutch.
    I acquired the necessary triple square drivers and a guide to swapping out the clutch.
    I even made a tool to remove the deeply-positioned 6mm Allen bolt so I could remove the transfer case that was welded to a 1/4 inch socket. It bent and broke at my ****ty weld, so I made up a better version with better welds and a 3/8 inch socket.
    When I tried it out, the tool did not break but, instead of a nice crack of the bolt, I got a soft, squishy give that indicated the bolt head was going to strip out instead of coming out. Not what was wanted.
    What can I do? Can I access the clutch without removing the transfer case? Is there a way to remove this bolt?
    Thanks,
    Tony.
    In theory, if you break the head off the bolt, you'll be able to deal with it, once the transfer case is out of the way, as the rest of the bolt will be in the gearbox.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Well, yes, but while the inside of the Allen head will round out, the rest of the head will remain, not snapping off.
      Ultimately, I may have to drill the head out if I weld up a 400mm long drill bit. A last resort.
      I did visit a VW mechanic, who was a bit grumpy. He was keen to charge me $1400 for a clutch kit and replacement dual mass flywheel, sight unseen, and became even grumpier when I suggested I could get parts cheaper from the net, muttering that he wasn't gonna do the job, etc. I left his workshop feeling very unenthused.
      Cheers...
        Did you try bashing the Allen key into the bolt with a hammer, to ensure it has seated fully?
        '01 Beetle 2.0
          That's a good idea. Right now, it is a little loose [I haven't stuffed it completely, just yet], but I will give it a try.
            Hey, I just discovered [via Dr Google] that a 8mm triple square driver can be bashed into a rooted 6mm Allen socket and may do the job. Stay tuned.
              You only get one chance though.
              '01 Beetle 2.0
                I've had good luck hammering the allen head in, most recently on my mates peugot 306, it wasn't a good fit and was rounding out, so we gave it a couple good wacks to realy seat it deep in the socket and worked great, we bought a new bolt though to put back in
                2002 Golf GTI - K03S | 3" Downpipe | 312mm DBA T3 Slotted with Forza Pads | | Forge 008 | Forge Hoses | ECS Performance Mounts | R32 and Urethane Bushings | Pipercross Filter | Sachs VR6 Clutch with 14lb Balanced Flywheel
                  Right, made the tool, chopped up a shiny new 8mm triple square driver and butchered a good screwdriver to make this:
                  So,it worked. I think it was loosened using the previous tool.
                  BTW, this is how I gained strut clearance:
                  Then I found I needed a 16mm spanner and an 18mm socket, so after cutting my finger, I called it a day. Supercheap had spanners for $2 each, so they were actually cheap for a change.
                  Questions:
                  1. I will be removing the flywheel to check the oil seal, is there a test for dual mass flywheel tolerance/ wear?
                  2. Can I reuse flywheel bolts?
                  3. Where can I get a clutch, flywheel, bolts, transfer case o-rings, etc.?
                    "Can of worms" time:
                    Should I get the cheaper single plate clutch kit? Surely a VR6 runs more smoothly than a 4 or 5 cylinder engine?
                      If its your daily driver i would advise against it. I get a lot of gearbox chatter when i went to a single mass.
                      2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
                        I agree. So, I am looking for an OEM clutch and flywheel kit to replace the heavily glazed and worn one that I have removed.
                        To finally remove the gearbox, I dropped the subframe [4 bolts], then unbolted the steering rack.
                        Since I will be removing the flywheel, I will replace the main oil seal as well.
                        Can anyone suggest parts sources?
                        Thanks...
                          How did you go?
                          How many k's has your car done?
                          Paul
                            Tony did you get bolt out of shaft or did you drill it out ? My bolt is in so tightly I can feel the 6mm hex starting to turn inside the bolt and strip. Someone must of been in here before. As it’s very tight. I don’t want to snap it
                              Rounding out the head is way more likely than snapping the bolt.
                              You are better shocking it than trying to turn with a ratchet or something. I usually just use an impact gun and out they come.
