My only big winge about my AVC9000=1 is that in bright light the screen is sometimes hard to see. Has anyone used LCD anti glare film and how does it look.
Volkswagen Golf/Jetta SAT NAV
Originally posted by Craig View PostMy only big winge about my AVC9000=1 is that in bright light the screen is sometimes hard to see. Has anyone used LCD anti glare film and how does it look.2008 Jetta 2.0T FSI | Campella White | HP Supreme Tint | AVC9000 | Digital TV Tuner | Parrot 3200LS bluetooth carkit
Originally posted by faisan View PostI have tried the anti glare film and it help at all. I have now built a shroud out of black plastic that goes over the top of the unit to help block sunlight.
This film is fairly cheap (about $10 on the internet being the only place I can find it). Did it make any difference or is it not even worth considering. I think I have seen a picture of the shroud you made earlier.Tx
Craig
Ncle NSW
Candy White 07/10 R36 VW Wagon. sunroof, tint, RNS510.
I wouldnt bother with the film to be honest. Mine only cost around $10 too and it did nothing. Its good as a screen protector if you need one.2008 Jetta 2.0T FSI | Campella White | HP Supreme Tint | AVC9000 | Digital TV Tuner | Parrot 3200LS bluetooth carkit
hey all - long time in between AVC9000 posts for me but I have a question - Does this unit fit into a current model Passat?
or is there a Passat-specific one?MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
Originally posted by Dyldo View Posthey all - long time in between AVC9000 posts for me but I have a question - Does this unit fit into a current model Passat?
or is there a Passat-specific one?2008 Jetta 2.0T FSI | Campella White | HP Supreme Tint | AVC9000 | Digital TV Tuner | Parrot 3200LS bluetooth carkit
Originally posted by faisan View PostI wouldnt bother with the film to be honest. Mine only cost around $10 too and it did nothing. Its good as a screen protector if you need one.
This is my wife's main complaint about the 9000 - ie glare making it hard to see.
Can you post a pic of your shroud please or point to one if you have already posted it?
thanks,..Neil
Audi Q5 2.0 TDI
sold and missed: '05 Touareg R5TDI
SWMBO: '08 Golf Pacific TDI DSG
thanks,
Is litterlly a strip of cardboard that I have inserted in the gap between th head unit and the dash fascia below the air vents. This helps block some of sunlight coming from the top of the dash but doesnt help with glare coming from the sides.2008 Jetta 2.0T FSI | Campella White | HP Supreme Tint | AVC9000 | Digital TV Tuner | Parrot 3200LS bluetooth carkit
Originally posted by faisan View PostI would rather not post a pic of the shroud as its fairly crappy and emabarrising
The problem we have is that SWMBO drives at dawn & dusk so it is glare from the sides that is the problem...
Anyone else with a solution?..Neil
Audi Q5 2.0 TDI
Anyone else with a solution?MY22 Tiguan 162 Elegance
Sound and Vision , Sunroof packages
Fireball Graphene Butterfly ceramic coating
Thinkware U1000 dash cams
Originally posted by allypally View PostNot true.
You can buy the VW Satnav after delivery. There may be a problem with supply though.MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
Hi,
Has anyone installed the current version3 unit? I've been told it has the MFD and CANBUS issues resolved.
Which Unit 9000 or 9000-1 requires the Y-adaptor to fix the reception problem? Is one of the unit better suited to the MarkV golf GTI? Which is the better unit?
Anyone in Perth with a new unit installed? Thanks!
Both the 9000 and 9000-1 need Y adaptors for the antenna.
I think most would consider the 9000-1 or WD6050 as the better unit. The menu looks slightly better and the unit looks just like the RNS510.
The only plus with the AVC9000 is that it has a bigger screen and rear USB input.2008 Jetta 2.0T FSI | Campella White | HP Supreme Tint | AVC9000 | Digital TV Tuner | Parrot 3200LS bluetooth carkit
