Where are you guys downloading the 5218SW from? Couldn't find the link on the RNS software page.
1 of 2
2 of 2
This is a sticky topic.
Re: Firmware updates for RNS510 units in Australia/NZ
Originally posted by Sammy125TDi View PostAny help getting my voice guidance and english guidance back?
I would try and load it again. Try 3970 if you think there are issues with 4120.
Sent from my HTC One X using Tapatalk 22011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Originally posted by lunchboxGTI View PostWhere are you guys downloading the 5218SW from? Couldn't find the link on the RNS software page.
Originally posted by aussietig View PostYes ... I've even reverted back to 4120 for your 90-5-5 partition.
Originally posted by kamold View PostIf anyone wants 5218 modified for partitions and vim etc happy to build it however as its a pointless exercise I havent done so.
Sent from my HTC One X using Tapatalk 2MY11 Tiguan 147TSI (SOLD)
Originally posted by kamold View PostSounds like you have an incomplete load of the firmware.
So frustrating!
Originally posted by Sammy125TDi View PostI've tried twice and get mid way before it throws a SWL error P010302. I had the same issue with 4020.
So frustrating!
RNS Firmware » RNS510 firmware 4210 modified for Australia
Took me several attempts to download it completely.
Then I used CDBurnerXP software to burn it using 8x speed, then verified it. I tried Nero earlier but failed verification.
Hope this helps.Mitsubishi Pajero Sport - Super Select 2WD/4WD
MINI Cooper S Clubman - FWD
Originally posted by nat225 View PostSam, I updated mine successfully this morning using the iso file link somewhere in the thread, but below same the link:
Hope this helps.
Originally posted by mackaxx View PostSo aside from update anxiety why would i want to upgrade my rns510 firmware?)
The modified firmware also changes your hard drive partitions from the defaults, which allow massive storage for the maps (to support euro maps that use a whole dvd, ours only needs a CD) so you can store more music.
If you're on Firmware 2xxx you don't get speed limit displays or points of interest.
You get different reverse guidelines (which feel weird at first, but are better once you're used to it)
You can have a custom boot screen (small I know, but a difference)
If your RNS510 is a late enough model, you can also have new voice guidance.
New maps require at least 3xxx (I'm only 95% sure on this one without reading the whole thread again.)
Did I miss anything?Biscay Blue 2009 R36 Wagon
RNS510 w/ Reverse Camera | Sunroof | Auto Tail Gate | 30,000kms
VCDS Changes: Rain Sense Auto Close | Tear Drop Wipe | Lock/Unlock Beep
Checkout my thread
From memory, custom boot screen works on most FW versions (but probably at least FW 3xxx or higher).
You need V4.1 or higher map to have custom POIs and running on at least FW 3XXX or higher.
Speed limit display first introduced on the V4.1 map and really has nothing to do with FW version.MY11 Tiguan 147TSI (SOLD)
Originally posted by aussietig View PostFrom memory, custom boot screen works on most FW versions (but probably at least FW 3xxx or higher).
I've contemplated upgrading to 3xxx firmware for the POIs, but to be fair I doubt I'd use them often and don't really feel like going through the hassle should I have problems during the upgrade process.2008 MkV Volkswagen Golf R32 DSG
Running 3970 and apart from the text to speech I'm not really seeing a good reason to bother then. In terms of the hard drive there's already 2500 odd songs on there without the need for the repartition, plenty of space left and the prospect of reloading all those songs after an unnecessary repartition is daunting.
Maps are v6 already anyway so I'm going to pass on the firmware for now methinks. I might be tempted with the VIM patch but can't really see a huge need for it anyway.
Maybe when the cars a few years old...
Thanks for the feedback though everyone, appreciated.
