HI All
I am trying to sort the bugs out before I tune my care.
I have recently done oil pickup, PCV valve, crankcase vent elbow and check valve tee as well as DV and replaced a few vac lines.
I'm now getting an intermittent rough idle which sometimes will cause a stall if I don't give it some throttle. Idle mostly sits 760 - 800 and fairly smooth.
I checked DTCs and only one I get is Immob denied start - Intermittent.
When I clear it, it resets the fuel trims.
I have driven about 15km today and 032 1 is -6.2 and 032 2 is -0.8.
What would be cause of too rich at idle? Ross Tech suggests Air Filter (easy enough to check / replace) but why would that not give more issues at partial?
Any other hints?
TIA
Trev
Any other hints?
TIA
Trev
