1.8T Intermittent rough idle and stall
  • 1.8T Intermittent rough idle and stall
    HI All
    I am trying to sort the bugs out before I tune my care.
    I have recently done oil pickup, PCV valve, crankcase vent elbow and check valve tee as well as DV and replaced a few vac lines.
    I'm now getting an intermittent rough idle which sometimes will cause a stall if I don't give it some throttle. Idle mostly sits 760 - 800 and fairly smooth.
    I checked DTCs and only one I get is Immob denied start - Intermittent.
    When I clear it, it resets the fuel trims.
    I have driven about 15km today and 032 1 is -6.2 and 032 2 is -0.8.
    What would be cause of too rich at idle? Ross Tech suggests Air Filter (easy enough to check / replace) but why would that not give more issues at partial?
    Any other hints?
    TIA
    Trev
    Please specify the car. I was assuming Golf but form another post, think it could be an Audi A4??
    They never run at 0% anyway, so in isolation, not a drama in my eyes .
    What are the sparkplugs like? Throttle body alignment. Probably worth a smoke check. https://www.youtube.com/watch?v=ofFafZfH0HM Put the Fire Dept on speed dial?
      Cheers Gav.
      B5 Passat APU engine.
      I'm using copper plugs at the moment and they look fine with a bit of corona. I have not checked the gap: I'll need some feeler gauges or something. I am getting CFs of 6-10 when I log it under boost but no actual misfire counts.
      I did a TBA last week. Didn't seem to make any difference.
      I guess I'll have to figure out smoke test...
        There's a solenoid relating to the charcoal canister on these that craps out, and makes them run stupid rich.
        Should be on the firewall on the driver's side.Maybe pull the hose off it on the engine side, and see if it makes a difference.
        '07 Transporter 1.9 TDI
        '01 Beetle 2.0
          That's loads of timing pull for a std engine. What fuel are you running? You can pull timing without misfires.
          Supercheap sell a two dollar round tool for checking gaps. Anything under 35 thou should be ok on a std engine.
            91 sometimes but usually 95. Mostly Caltex.
              Can you show me a pic of this solenoid?
              Here is what I did tonight.
              I removed TB, cleaned it and the IAT sensor and re-fitted.
              Removed Air Filter, replaced with new.
              Removed ICM and cleaned the surface, added fresh thermal couplant and re-fitted.
              Removed #1 plug and checked. BKR6EK. Has dual electrodes on the side with curved tips so you can't really check the gap. Little coating but not too bad. Will order new ones anyway. Probably done 15k km.
              I then reset the codes (none) and did TBA. Finished OK.
              Then went for a 10km drive. So far slightly better idle, very small idle and partial trims.
              Good start.
              Now I gotta fix these CFs.
                Run it right down and put 98 in. Problem solvered. You CANNOT treat it like a corolla. It would be making 100hp.
                  My Corolla had a 10.5:1 comp ratio, so it liked the 98 also.
                  Here are 2 pulls with much better CFs, on mostly 98RON. The mid range CF that disappears with revs is a little odd.
                  Now I want to add some boost.Click image for larger version
ID:	1816832Click image for larger version
                    Now I want to add some boost.[ATTACH=CONFIG]16177[/ATTACH][ATTACH=CONFIG]16176[/ATTACH]
                    It depends on what the ECU is requesting for a timing point. Pulled timing coming and going isn't unusual.
                    Also if the trims are out you should check all the vac pipes under the manifold.
                      Thanks Gav
                      I think my ME7Logger reports the trims slightly differently to VCDS.
                      It says my Partial is around 1 and my Idle is around -6.
                      -6 should mean it is pulling fuel from being too rich at idle. I would have thought a vac leak would give me a + at idle, not a -.
                      I can't attach the log here.
                      Try this link. https://drive.google.com/file/d/0Bwj...ew?usp=sharing 2.4MB of data
                        Thanks Gav
                        True, have a look at the water temp input to the ECU maybe it's not seeing a warm engine?
                          tmot Coolant Temp log started at 20 and ramped to 68 during the log.
                            Gauge reads normal?
                            Is it manual or tip?
                            I'll have a look at mine tonight if I remember. My ECU ends 018AR. It was shocking a while back, lots of busted breather pipes and stuff.
                              Gauge warms up and sits on its fake 90deg perfectly.
                              Manual 5speed.
                              My ECU is 018AC. Both AC and AR are similar narrowband ECUs with very similar maps but most of them are in different locations.
