Another Wreck, another Race Car.....
  • Good news Peter, great work so far!
    • woohoo, congrats Pete, great news.
      • Spent a few nights this week sorting out cam angle sensor.
        Had to make a hybrid of a new KR hall effect sensor and an ABF housing so I could use the single window rotating vane.
        Don't need to distribute spark so I made a cap.
        I need a cam angle sensor to run coil per cylinder and sequential injection.
        7? MK1 Caddy
        79 B1 Passat Dasher Project
        12 Amarok
        • Started bolting down the electrical stuff.
          Here's the switch box a little closer and a little less green.
          Battery is bolted down in that position now.
          Made a cage for the ECU and bolted it in.
          Found somewhere to mount the logger.
          Interior taking shape. I had to put the seat back in so I could position the switches.
          Routed and secured the hoses in the engine bay.
          7? MK1 Caddy
          12 Amarok
          • Installed the fire system.
            One nozzle in the engine bay.
            Battery cutoff on the left and fire extinguisher on the right.
            There's still decals to put on to mark the functions.
            Second nozzle in the cabin pointed at the driver's midriff.
            Still have to clip down some of the cables and hoses.
            7? MK1 Caddy
            12 Amarok
            • Hi torque starter motor.
              These are a geared unit and look to be an adaption of the 16v Toyota starters.
              As supplied it was a little too close to the radiator so I removed the adapter plate and reworked it to rotate the starter into a new position.
              7? MK1 Caddy
              12 Amarok
              • Finalised the mounting and linkage for the clutch slave cylinder. Just need to sort out a custom hose for it next Saturday.
                7? MK1 Caddy
                12 Amarok
                • Roll cage padding can go in now.
                  This is the new spec SFI style padding, it's really dense and is easier to work with.
                  7? MK1 Caddy
                  12 Amarok
                  • Key chain quick release for the isolation switch so I can remove it from the car when it's not in use.
                    7? MK1 Caddy
                    12 Amarok
                    • FRICKEN HELL, all those little bits are AWESOME!!!!!!!!!!!!!
                      well done pete, can't wait to see it at DOVW
                      '76 Golf LS Swallowtail 4dr
                      '76 Golf Swallowtail 2dr
                      '89 Golf GTI 16V 2dr
                      • you've definately been busy, great work Pete!
                        • CAMS came out and sealed the motor last night.
                          Sump and head are wired on and tagged.
                          Now to press on with the rest of the assembly.
                          7? MK1 Caddy
                          12 Amarok
                          • great news!!!
                            quick question:
                            what milling machine do you have??
                            looks like the perfect size for home use.
                            • another step done Peter. Such a bummer I can't make it to DOVW this year to see this beauty...
                              • Originally posted by Stiggy_21 View Post
                                It's an Hafco HM-46 M123 | HM-46 Mill Drill - Geared & Tilting Head | machineryhouse.com.au
                                There's cheaper and dearer options depending on the column style and accessories.
                                Mill Drill Milling Machines | machineryhouse.com.au
                                I've fitted a power feed on the x axis. For Christmas I might buy myself a DRO to go it.
                                It's a good size for working on car stuff, It's a Mill/Drill so it's pretty versatile.
                                I just made a new drawbar for it so I use a wider range of tooling.
                                They come with a 1/2" whitworth drawbar whereas all the cheap tools on ebay are M12..
                                Of course The minute I get around to making a metric drawbar I discover that you can buy them on ebay for $19
                                7? MK1 Caddy
                                12 Amarok
