OCTAVIA III Owners discussion thread
  • Originally posted by Jondalar View Post
    Spinifex this is where I got most of the adaptations I used: Octavia III VCDS Adaptations - tried and tested - Diagnostics & VCDS - BRISKODA There may also be another thread on Briskoda as well.
    Cheers,
    Karl
    Yep thanks Karl - that's where I've been looking as well.
    I'll have a better play around with it tomorrow, after some decent sleep and in proper light !!!
    2016 Skoda Octavia 162TSI RS Wagon
    (Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
    Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
    • When enabling the traffic notifications, the number you need to enter for Australia is 1024, as mentioned in this post:
      http://www.vwwatercooled.com/forums/...ml#post1163723
      Also, a lot of instructions refer to RDS and TP settings, presumably in the radio settings. I only have 'Radio text' (or maybe 'Radio data') both before and after the change. That setting was on when I got the car and I've not touched it since.
      MY16.5 Octavia RS wagon, manual, Moon White + tech pack + 18" black pack.
      • Originally posted by woofy View Post
        The auto tail gate Hawk (Aaron) and I had no luck getting to work earlier in the year in my Jan MY16 build car but he had issues with his software so will organised a time to try again.
        I have enabled tailgate close with both buttons, using the regular instructions and OBDEleven. This is on an April build car. I made sure I entered the access code 12345 as soon as I went into the controller. Only then did I go into Adaptations.
        • I can confirm my 2016 build (March I think) works with the tailgate close on button and keyfob.
          Managed to code this today using OBDeleven dongle.
          I also got my live traffic enabled, but I can't get the comfort indicators to flash 5 times. I've set it in the OBD11 app, from 3 to 5, but when using indicators it only flashes 3 times. Cannot find any settings in infotainment where I can select the number of flashes.
          And cannot not work out how to "set bit0-2 to 03" to enable high beam assist when long coding, as is instructed in the excellent Briskoda forums linked earlier.
          I can select byte 02 as instructed, and bit 1 is enabled. Bits 0 and 2 are unticked. What exactly do I tick/select here, to set bit0-2 to 03?
          Image attached
          • so its $500 for rear heated seats, but they will never tell you that....
            Website says "heated front and rear seats - $500" - Why would they even bother with a heated rear seat only option.?
            • Originally posted by Spinifex View Post
              Image attached
              Well, if they mean set it to 3, that's the first two bits set - bit 0 and bit 1. In binary, bit 0 has a value of 1, and bit 1 has a value of 2. 1 + 2 = 3. That's my educated guess.
              • From memory to get the comfort indicators to change setting you have to reset the lights after changing the coding for it to work.
                i found 5 too long and settled for 4.
                2012 MY11 Cappuccino Superb Elegance, TDI. (Gone)
                2014 MY14 Race Blue Octavia Ambition Plus wagon, TSI, Tech Pack. (Wife's)
                2014 MY14 Cappuccino Octavia Elegance hatch, TDI, Sunroof, Tech Pack, Towbar. (Gone)
                2017 MY18 Lava Blue Superb wagon, 162 TSI, Sunroof, Tech Pack, Comfort Pack, Cream Leather, Towbar (Mine)
                • How do I "reset the lights"?
                  • Originally posted by pjam73 View Post
                    I can understand your educated guess..... that's what I thought too.
                    BUT..... it says set bit0-2....... so my understanding is I have to set bit 0, bit 1 and bit 2.... all to a value of 03?
                    I need to set bit0-2 to a value of 03..... but not setting byte02 to a value of 3.
                    What happens to the other pre-ticked bits 3&4..... so I have to untick those and only tick bits 0&1, to get a result of 03?
                    Sorry to be such a n00b..... don't wanna mess things up!
                    • Manual gearbox feel
                      A question for those of you with a current model Octavia with a manual gearbox...
                      Do all your changes feel 'smooth' in respect to the movement of the gear stick? In doing 1st-2nd changes, quite often it feels like the gear stick is hitting the sides of the gate as it goes into 2nd. It does get smoother after a few minutes driving, so perhaps it's related to oil temperature?
                      In going from 3rd-4th, does it seem to stick slightly just rearwards of neutral, requiring a futher push to get it into 4th? It's never happened yet but part of me thinks one day I'll be slightly distacted and it'll jump back out.
                      I must say the car has only done 1400KMs so it is still bedding in, and I'm slightly OCD about my gear changes so I'm probably over-reacting...
                        My Mk2 with a DieselGeek short shifter is absolutely horrendous when its cold...
                        The Mk3's I've driven have been good. But they've all had less than 200km!
                        My advice would be to keep driving it, and see what happens. It'll probably be fine.
                        Not including hers...
                        • 1st to 2nd on my Mk3 manual (1.4tsi) has never been as smooth as it should be, and often baulks although if I rev out 1st more then the change improves. I consider the gearing gap on my mk3 between 1st/2nd is too wide and contributes to the problem,
                          The manual gear change on my 5 speed mk2 1.9d diesel was much better, but I thought the overall gearing between all gears was better too.
                          I have adapted to my style to 'pause' slightly in Neutral on the 1st/2nd change but the other gears are fine for me
                          I drove a manual Focus (1.0tsi) in the UK last year and the gear change was superbly buttery smooth, especially 1st/2nd. No notchiness, no baulking, it just slipped easily across. Unfortunately not all things perfect as the clutch was too light and it was difficult to know when it was actually engaging.
                          I have also driven other cars with much worse gearchange issues so I can live with it, but yes it would be nice if it were better.
                          PS 30,000 kilometres and 30 months old
                          • Dumb Question,
                            but do the MkIII's come with floor Mats? As in, be standard with the car?
                            Skoda RS 230
                            "The Grey Ghost"
                            SG-TP-AB RS230 - Timeline
                            • They were standard with my car in April from the Brisbane Skoda dealer...
                              Originally posted by HPRS230 View Post
                              Dumb Question,
                              MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
                                Thanks for the reply, cheers.
                                Skoda RS 230
                                "The Grey Ghost"
