Originally posted by wfdTamar
									View Post
Mysticality's Light Thread!!
 In all honesty, its not great. It really is a lot closer to worthless on large flat empty spaces. It still lights up the road for maybe 150m but apart from that, not much else.Originally posted by brad View PostI'd be interested to see it without all the hard surfaces to bounce off
 The roos are still visible though
 Either way - I'll collect a whole bunch of pics when I can! 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm. 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
 Not including hers...
 Also do you know how they wired it up? Where they connected things?
 Just put led replacement lights in my boot off ebay - $37.
 eBay Australia: Buy new & used fashion, electronics & home d
 Got led interior lights coming from Superskoda.
 Octavia II 04-12 - FULL (front+rear) led dome light kit - KI-R : superskoda.com
 €45 (A$57) free shipping (might be able to get them cheaper off ebay but I couldn't be bothered )2008 Skoda Octavia Elegance TDI 4x4 wagon
 Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
 They wired up the light bar relay to the left hand H1 bulb... So, the bog standard way to wire spotties.
 The LED boot lights are bloody awesome, I've got some SuperSkoda ones. 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm. 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
 The SuperSkoda interior lights don't work properly. For a start they send 2 kits, each of which have 1 big 'globe' and 2 small ones. That's what my front light has, but the rear one only has a single globe. So that's 2 small 'globe's' I've paid for which I have no use for.
 I say 'globe's' because they're actually led panels connected to plugs that go where the conventional globes go. Yes they're very bright, but it's a very white light.
 The problem is with all 3 front led panels in the 2 smaller ones don't ever turn fully off. They stay on very dim all the time the light is off. If I put one of the normal globes back in the remaining small led light then turns off. So I have the centre and drivers side light very bright white and the passenger a dull yellow. Looks naff.2008 Skoda Octavia Elegance TDI 4x4 wagon
 Re: Mysticality's Light Thread!!
 They work properly its just that they operate on such a low current draw they stay on like that.
 Its what allows the 'soft' on and off with incandescent globes.
 If you don't like the little glow you will have to put some resistors inline to provide enough impedance to have them go dark.
 When you lock the car the circuit goes fully off so they go dark.
 Sent from my HTC One X using Tapatalk 22011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
 I'm not so sure that they do!Originally posted by kamold View PostWhen you lock the car the circuit goes fully off so they go dark.
 Either way - mine don't bother me. They don't use THAT much power, afterall!!2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
 Cant wait to see the lights in the dark one day! (I mean 'night' sorry)
 I guess you will lead the pack of us on the 2nd if it gets past dusk then hey??2018 Ralyee Green RS wagon. Fully optioned.
 I guess the best description would be a bright white version of a mid-2000's Falcadore high beam!...Originally posted by Tigger View PostCant wait to see the lights in the dark one day! (I mean 'night' sorry)
 But yeah, probably. 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm. 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
 No they don't go off when you lock the car - so they're on all the time. They cost $57 so I want them to work properly! Otherwise I could have got some cheapo ones off ebay for the same result.Originally posted by kamold View PostThey work properly its just that they operate on such a low current draw they stay on like that.
 Not sure if I like them anyway. They look a bit too aftermarket. The glare is too strong.Last edited by wfdTamar; 24-01-2013, 06:52 AM.2008 Skoda Octavia Elegance TDI 4x4 wagon
 They must have changed the lights. Mine stay on slightly until I lock the car. Then they turn off. Superskoda kit.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
 There's a low voltage sent through the interior bulbs all the time... Thats what you're seeing.
 Its not powerful enough to power the incandescents, but it can power the LED's. 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm. 2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
 Bit of a thread dig...
 Has anyone had any luck/advice on replacing the H1 high beams on a 2012 Octy with HIDs?
 I figure that as the low-beams stay on with the high-beams, it should functionally work well (no warm-up issue).
 Thinking a 55W HID kit would throw a lot of light, and not draw any more power or produce any more heat, than stock halogens.
 Would much rather super-power high-beams, than adding in any additional light fittings.Skoda Octavia v/RS - 2012 Petrol 6MT
 They are illegal to fit without washers and auto levelling and dont work well if fitted in the stock reflectors as they are not designed for HID and tend to flare like the sun.Originally posted by Andres View PostBit of a thread dig...
 Not that it seems to stop some people from doing it.Last edited by Guest001; 19-09-2014, 05:17 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
