Thanks for that Transporter up until the AT failure I will admit being a bit in the dark regarding VW technology but I sure learnt fast after that one .
T5 DSG dropping gear? WTF HELP?
A little update on the wheel issue, didn't want to start a new thread again.
Van just had service done and they had agreed that next time it came in they would fix the damage they had done to the passenger side front wheel while it was in for mechatronics replacement.
They fixed it up and you can't even tell it was damaged
Only problem is looks like they failed colour match 101
I'm about to call them back. I didn't notice it at the dealer as it was parked in the shade and I only really looked at the front to see what they had done. This just keeps getting better!
Hi Bruce,Originally posted by byronbus View PostOk, so after all that, i have a 2013 multivan, when is the best time to get extended warranty... does it get more expensive the closer you get to the factory warranty expiring?
You can extend the warranty at anytime while the van is still under the original warranty.
I should have done mine earlier, as it is more expensive since the Golf DSG problem hit the fan. Prior to that is was $2400, I think it is now $4000. I'll have to check up on that soon.
