T5.2 OEM Radio Options - fitted post delivery
This is a sticky topic.
  • #46
    Hi Sharkie
    just ordered a comfortline and want to fit a better radio and nav. do you still recommend the rns510 or are there other options that have come out since you did your conversion
    also, I am a bit worried about damaging something when pulling out the covers and radio surrounds any special tools or should I just get it professionally installed?
    thanks
    • #47
      Hey mate, I'd still recomend the RNS510 above anything else. RNS510's are also constantly being upgraded, so a late model (H or P) is the way to go. Cheaply available on eBay from Europe. I bought 1 last week for the Amarok, was delivered in less than a week!
      Fitting is really simple, all up 6 screws if I remember correctly. The rest is plug and play. Lots of RNS510 fitment guides on youtube, have a look and save your self $150 installation fee.
      • #48
        Thanks Sharkie
        I bought a set of removal tools from ebay for $3! so will. do I need to specify that I need Aussie maps if I buy from a European seller? also do you have any idea about rear cameras? I watched a clip on youtube and the wiring coonersn me, do you know if the wiring is already there or do I have to pull the wire from the back to the radio?
        thanks for advice mate, I am probably going to need more and appreciate you time
        • #49
          Need an RCD 310 or RCD 510 Call me as I have discovered a secret stash at a dealers pre-delivery section. They dont know what to do with them. I saw 10 RCD 310 (probably for free) and 4 RCD 510 sitting around and was told there are more. Jan @ Motexion 0433 97 55 44
          • #50
            Hi all
            i just fitted the rns 510 into the new multivan and it turned on, but when i go to the nav options there are no maps, i am thinking that it is because of the gps antenna - which is magnetic - is mounted down low under the unit - the only metal in the vicinity i could find - so may not be able to get signal?
            my question is where have people mounted the GPS Antenna when they have upgraded to the rns 510?
            Also, two of the 6 screws seem to be very hard to screw back - i stopped so as not to damage the plastic - any tips?
            Thanks guys
            Arif
            • #51
              Originally posted by arif View Post
              Hi all
              Thanks guys
              Arif
              All the screws should go in easily. I'd pull them all out again and start again ensuring all bits are alligned properly.
              The GPS antenna must be as close to the top as possible. Down low will see it not finding any satelites. I use velcro stickers these days and attach to the bottom of the top tray. When you have it all in, park on your driveway with a clear sky above you and give it a few minutes to find the satelites. It needs at least 4 to work properly and 6-7 out of 9 is normal.
              First off I'd recommend leaving the top tray off and positioning the antenna on top of the dash. Once its found a few satelites and brought up the map then move to just below the tray.
              • #52
                Having spent so much on other options on our 2011 T5 we settled for the bog-basic radio (RNS 210?).
                All I want is to retro fit a USB port, hopefully in some not-too-untidy looking place.
                Can anyone out there point me in the right direction?
                Might it involve resetting any codes? If so, where the hell does one find said codes.
                Too much technology in new vehicles for this old fart, I can tell you!
                sigpic2011 T5 132kw 7spdDSG 4motion, '89 Citroen 2CV, 2006 Subaru Forester SG 5spd
                • #53
                  There is VW Media Interface (MDI) where you can fit the USB, ipod adapter. You don't need radio PIN to fit it, if that's what you ask.
                  Other than that, if you DIY I'd coded it for you for free, if you come to me.
                  Performance Tunes from $850
                  Wrecking RS OCTAVIA 2 Link
                  • #54
                    Thanks, Miro ... what does the finished installation look like - does it utilise any of the available slots (or whatever they're supposed to be called) in the dash?
                    • #55
                      The MDI box is hidden and the cable for the USB drive or iPod is in the glovebox.
                      • #56
                        Hello guys,
                        Having just ordered a new comfortline I have begun searching reverse camera options as I could not see the value in 4k for the option from factory. So far my research tells me that I should be ordering either:
                        RNS510 from ebay $900 ish
                        RCD510 from ebay $300 ish
                        and:
                        Genuine VW reverse camera from ebay $260 ish.
                        Sounds like fitting is simple plug and play with only basic hand tools required.
                        Can anyone who has retrofitted a reverse camera to their multivan please advise what they ordered, how well it works and where they purchased from. Im not fussed on the sat nav so Im leaning towards the RCD.
                        Also I just assumed they multi would come with phone blue tooth controls on the steering wheel, can anyone confirm before I check with the dealer. If so I would also want the new head unit to be compatible with these controls.
                        cheers and thanks in advance,
                        • #57
                          I'd always recommend the RNS510 above the RCD510.
                          The RNS510 has the SatNav (which I actually quite like) which fully integrates to the MFD (very handy to provide route instructions), a 30GB (or 40GB depending on model) harddrive to store music on (lots and lots of CDs worth) and the ability to play DVDs.
                          Also, a RCD510 that has the yellow plug for the RVC is more expensive than the "cheaper" non RVC versions. Budget about $350 for it.
                          RVC camera bit of a pain to fit. For $270 I'd recommend the genuine unit, however can get a "guaranteed to work" aftermarket unit here : RGB Parking Camera FOR RNS315 RNS510 810 RCD510 Rear View Reverse Backup Camera | eBay
                          I believe the latest Multivans come with BT and MF steering wheels as standard, but this would best be checked with the dealer as it will be a pain to retrofit (do-able though).
                          • #58
                            Please, post only the OEM audio related topics, as per the title of the thread.
                            • #59
                              Umm so where did the posts go Transporter someone had asked a question about shades that was the reason for my post .. I believe it was beneficial to any one with a headunit with sunlight issues , but I accept your moving them .
                              • #60
                                Nowhere, it got deleted. It was at least a second time I've cleaned up this thread. The first time I've moved the off topic posts to a new thread. It's somewhere in the audio section, if you find it, I'd moved the deleted chat in there.
                                This is sticky thread and I intend to keep it clean. Please, don't post the Chinese aftermarket radio and other unrelated info in this thread. People who want the info on RNS units aren't interested in it.
                                Sorry for any inconvenience.
                                You are more than welcome to start your own thread about the Chinese units.
