I'm a newbie - I purchased a VW T5 2.5TDI LWB about 12 months ago.....
I have had some issues which after searching this forum was able to deal with them.
Recently I have had what I believe were overboost issues where the van would go into limp mode shortly after starting and going up a short incline, this happen on 3 occasion. To deal with this issue I used fuel additive to clean the turbo etc - it seams to have worked as the problem has gone away.
Yesterday while driving home the van went into limp mode again, i automatically assumed that it was the same issue, I turned of the ignition to reset however the van struggled to start and vibrated when trying, after a while it did start. Once i turned the ignition off again at my next stop the same this happened.
I scanned the error codes it it came up with P0864.
I searched this forum but found nothing. Search google and it appears to be an issue with the traction control module.
It so happened to be that I was booked in for a service today and the Local VW service centre, hopefully they will be able to sort it out and I wont be out of pocket too much.
Has anyone else had the same issue?
