I'm after a second opinion on a recent issue that's come up
Over the last couple of weeks on startup the engine has started chugging occasionally. Once warmed up all fine.
No codes etc. Didn't think much of it it wasn't constant just every now and again. Wasn't like it dropped a cylinder just the odd misfire.
Today the issue has started occurring all the time at idle.
Rough idle (like a lumpy cam), rpm hunting between 750-900 rpm and occasionally if I coast to a stop immediately after I get off the gas the rpm goes up then slowly comes down.
Otherwise car drives fine you wouldn't know there was an issue.
I pulled all the plugs tonight (bkr7e gapped to 28 thou, 2500kms on them) and one was no like the others. Nothing major but noticeably different. I suspect I may have a misfire on this cylinder. I've popped in the pre-service plugs and the issue remains. I've swapped the suspect cylinders coil over to another cylinder but I don't really want to drive it much to see if the issue moves.
Anyone had a coil fail over a period time? I've had them go on my previous polo but they just stopped working one day there was no gradual decline.
I've still got all the sai connected, does that affect idle after warm up? I wouldn't know if it's throwing a cel as it's been coded out of my tune (and I have been lazy about removing it all)
