1. audi TT ball joints #8J0407365 & ..366 or Meyle equivalent #1160100022
2. There are 3 ball joint locating dimples. Drill them out. Their internal remains will need to be filed dead flat. Not fun.
3. Shocking photo but this is what the dimples look like on the inside. I had a second set of control arms so did it in a bench vice with a file. Its feasible you could do it in the car with the strut pushed out of the way if you could fit a small dremel bit up there. Either way this part of it is a pain.
4.
The internal faces have to be dead smooth. No relic of the dimples or anything otherwise the ball joint will not slide in.
5.
Lucky for us the outside two bolt holes line up. Place the new ball joint onto the top of the control arm in the fully out position. Make sure the left side control arm is getting drilled with the left side ball joint. The ball joint socket is staggered forward towards the front of the car for more castor if they are not marked. Then mark where the new centre hole has to go and drill it. Do not oversize it drastically as the new hole sits very close to the old hole and you don't want them to run into each other.
6.
I think I drilled it 9mm so that there was some wriggle room in case the castor needed to be evened up. The top holes I left alone.
7.
I then took a file to the ball joints already elongated holes. Guys with mk 2 fabias that use these ball joint get there stock neg camber taken from 1 degree to 1/1/2 degree if they are put straight on. I decided to elongate the ball joint holes to get that bit extra if I need it. These joint will still be stronger when adjusted fully out since the centre hole is a full 10mm deeper into the control arm than stock. The hole on the bottom has been taken out with a round file.
8.
This is the fully in position.
This is the fully out position. So theres 10mm of adjustment, and from a quick look these ball joints sit the stub 15mm further out to begin with so there should hopefully be up to 2 degrees of neg max. I just hope that if I loose castor it isn't too much, and there is also enough wriggle room to square up the castors on each side.
9. - I got this idea from seeing guys do it on Fabia mk 2's where it bolts onto the top of the control arm. Fabia mk1's share our control arm. The ball joints for mk1 and mk2's share the same part #. Therefore if these joints fit ok into mk1 and mk2 fabia hubs then they should fit into ours. If they don't then I filed my hands to the bone for nothing and went public with my stuff up.
10............ i'll keep you posted after I do the fit up and alignment.
4.
5.
6.
7.
8.
