First dry night in a while so started getting the car ready for the weekends hillclimb. I fit my 20mm spacers to the front and its a no go. The wheels sit way proud of the guard lip now that the audi joints have increased the track - it just looks wrong really and would definitely get knocked back at scrutineering on the grounds that its not street legal. That left me only able to run my 12mm spacers. With them fit up, the front track is a touch wider than it had been pre-ball joint mod with the 20mm spacers fitted. But because of the camber it has now it doesn't look too out of place because the tyres are tipped in at the top.
I can confirm that the audi ball joints have changed the front geometry noticeably. When the front end was standard, the 12mm spacers felt weird I think because they were running at close to zero scrub eg strange squirming on down hill sweepers and really light pedestrian speed steering. The 20mm spacers had the steering feeling like standard again, nice and weighty, but obviously with positive scrub and a much wider track. Now, because the audi joints pivot much lower relative to the hub than the OE ball joints, the scrub radius will have moved more towards zero and so it takes less spacing out now to achieve the same result as before. This time the 12mm spacers felt wicked with nice meaty steering weight again and lots of feedback.
Theoretically now with a higher roll centre the car should be less inclined to roll, and by achieving the same wide track but with narrower spacers my wheel rate won't have dropped as much as when I had the 20mm spacers on, so overall the car will have more front roll stiffness than before (which you can definitely feel) so I should be able to get away with the front ARB on soft for the weekend I think and hopefully get some good drive coming out of the hairpins.
