Depending on the tyres 2 deg is low for track only but pretty much the limit if you are driving on street (ie to and from events). Hillclimbs being so traction dependent and relatively low speed I think you are in a good position
Most strut tops are stet up for either Camber or Castor, You want as much castor as possible on FWD so it is common enough to do bulk movements of camber from the bottom (balljoint or strut leg) and fine tune from the top hat keeping the castor
