If I wanted to swap between different pads and rotors for road and track use, are the caliper to carrier bolts reuseable or do need to source a new set of 4 each time I do a swap?
GTi front brake caliper bolt reusable?
Resident grumpy old fart
VW - Metallic Paint, Radial Tyres, Laminated Windscreen, Electric Windows, VW Alloy Wheels, Variable Geometry Exhaust Driven Supercharger, Direct Unit Fuel Injection, Adiabatic Ignition, MacPherson Struts front, Torsion Beam rear, Coil Springs, Hydraulic Dampers, Front Anti-Roll Bar, Disc Brakes, Bosch ECU, ABS -
Originally posted by kaanage View PostIf I wanted to swap between different pads and rotors for road and track use, are the caliper to carrier bolts reuseable or do need to source a new set of 4 each time I do a swap?
EDIT seen you have GTI calipers now I read it properly....Last edited by h100vw; 20-08-2015, 09:10 AM.
The front carrier (190Nm) & slider (30Nm) bolts are re-usable.
The rear caliper carrier and the slider bolts should be replaced every time (in theory). You can probably get 2 or 3 tightens out of them or simply replace with grade 8 std boltscarandimage The place where Off-Topic is On-Topic
Originally posted by brad View PostThe rear caliper carrier and the slider boltsResident grumpy old fart
Isn't that the rear brake?Resident grumpy old fart
