turbo to manifold bolt torque specs
  • turbo to manifold bolt torque specs
    Hi,
    Nearly ready to get my old modded K03s and ported OEM manifold back into the car. Where im confused is that a german torque spec list per bolt size that we have at work says 10mm bolts in that pitch should be 43Nm fo 88's, 63Nmfo 10.9's and 74Nm for 12.9 high tensile which is what the VW bolt are. So why (admittedly on vortex) am I seeing figures of 26lb/ft (35Nm) being kicked around? Anyone know the official spec?
    Also exhaust mani to head nuts- I've found 25Nm. sound right?
    sam
    Dropbox - polobjx.pdf
    Engine manual for your viewing pleasure Sam.
      bloody hell that was quick! last night at work and needed to borrow the correct torque wrenches so didn't have time to trawl the net for too long. thanks.
        I hate to be more of a pain than usual but I'm not allowed to download/access dropbox on work computers. know them off top of your head?
          woop - I'm in! no worries Looking now. thankyou thankyou
            mani to head nuts = 25Nm
            mani to turbo bolts X 3 = 40Nm
            turbo to downpipe = 40Nm
            sorted thanks Gav. Still 40Nm for a 10mm bolt is pretty pissy and doesn't sound like enough. Maybe the bolts which are 12.9 stretch somehow. Might just run 12.9 cap heads from work instead and get a lot more threads engaged (the OE's don't even go 2/3rds of the way into the available turbo threads). I'll be using big diameter Nordlocks too.
              oh!! thanks!!
              can I be really rude and ask if there's any chance you could upload the electrical manual, if you have it? I would really appreciate it
                thank you very much - legend
