I think I have the MFD+ speedo as there is a little phone symbol as one of the buttons on my steering wheel? How can I tell if I have one or not?
All your MY12.5+ Bluetooth Touch Adaptor Answers
Only the Polo GTI has the MFD+Originally posted by onelungwonder View PostI think I have the MFD+ speedo as there is a little phone symbol as one of the buttons on my steering wheel? How can I tell if I have one or not?
The pairing menu in the middle of the tacho won't be there on a normal polo, but I do believe VW PHONE will be discoverable on the phone for about 10 seconds after turning on the car.Originally posted by ill0gitech View PostDo you experience issues with the MFD saying "touch adaptor not installed" if you unplug the touch adaptor?
Do you have the Bluetooth sync options described at the start of the guide?
But yes it is a little risky running the BT without a MFD+, Touch adapter or RCD/RNS 510.MY16 Octavia RS 162 Race Blue Combi
Check your VCDS settings.Originally posted by ill0gitech View PostDo you experience issues with the MFD saying "touch adaptor not installed" if you unplug the touch adaptor?
I got mine done by another forum member here.
It doesn't matter whether or not anything is in the actual cradle because it's connected via bluetooth and not via the dock.
My dock simply works as a charger.
Worst bit is... changed phones now and can no longer use that damn cradle unless I buy another one!!
I should have spent the extra $10k to get the GTi! The VW PHONE is discoverable for a little bit, I don't get the "touch adaptor not installed" warning. I do have Bluetooth options on my RCD310 though, I might take some photos of the menu and post them but will try and get someone to help with the with VCDS settings.
I Thought I'd put pics of my Universal XL installed since it is difficult to find pics of it all installed online.
And just a note the power cable normally just hangs down on the left.
I've wrapped some tape around it so it is fat enough to hold in behind the unit so it is a little neater.Last edited by dening; 18-08-2013, 03:03 PM.
You should start by reading the start of this thread.Originally posted by POW View PostSorry for being new with my gti. what do you mean coding? Without this being done,what will happen?
Thanks for the pics dening, I've been trying to get my head around how it works.
Is the cable on the left hand side fixed, or detachable?
Do you get a signal boost when it's plugged to your phone? Or just the power? (not sure if this was covered already)Mk8 Golf GTI
Yeah the cable is removable, it's a right angle mini usb then the micro usb for the android phone. I've tried to find a neater one with an up angle micro but haven't had any luck.Originally posted by ill0gitech View PostYou should start by reading the start of this thread.
The bury site says that there is a signal boost, I'm not sure how it might work though and haven't noticed anything yet.
There will be a signal boost, the bury dock is directly connected to the antenna on the roof of the car. I believe they put a loop in the dock. You probably won't notice more bars (receive), but it should really help the phone getting the signal out of the giant metal box that is a car (transmit).Originally posted by dening View PostYeah the cable is removable, it's a right angle mini usb then the micro usb for the android phone. I've tried to find a neater one with an up angle micro but haven't had any luck.
The bury site says that there is a signal boost, I'm not sure how it might work though and haven't noticed anything yet.MY16 Octavia RS 162 Race Blue Combi
