Hi Guys
Hope everyone doing well.
I need some help with my B7 2013 2.0TDI (63,000Km)
This morning I was parked in the driveway without handbrake and engine ON.
I shift from P to D and the car did a jerk...after a lot of lights and error message come up on the dash.
1)Tyre Pressure fail
2)Error AFS (adaptive corner light)
3)ABS Error
I also notice that the push button for the ASR is not working.
I have the VAG cable so I connected and scan the car. The follow are the codes:
My question are:
1) I try to reset the codes, but the errors are come back. Very interesting to know why some error from 2015 and 2016 are still come up during the scan?
2) The tyre pressure monitor is the "indirect" one that use the ABS sensor....Can possible be just a faulty sensor that bring up all these errors?
If anyone can help I will really appreciate.
Thanks
3)ABS Error
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 3C 42 44 46 4C 4F 52
53 55 56 61 62 6C 72 77 A5
VIN: Mileage: 63270km-39314miles
Address 01: Engine (J623-CFGC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 RG HW: 03L 907 309 AE
Component: R4 2,0L EDC H28 4679
Revision: 41H28--- Serial number: VWZCZ000000000
Coding: 001D0012042501080000
Shop #: WSC 00028 028 00211
ASAM Dataset: EV_ECM20TDI01103L906018RG 003005
ROD: EV_ECM20TDI01103L906018RE.rod
VCID: 0008182F9B10A43E5D-8054
2 Faults Found:
5290 - Throttle Actuator Control Circuit
P2100 00 [032] - Open Circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
5305 - Throttle Position Sensor (G69)
P0123 00 [032] - Signal too High
Freeze Frame:
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
1 Fault Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 1
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:25
Address 03: ABS Brakes Labels: 3AA-614-109.clb
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 4
Reset counter: 159
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:25
Freeze Frame:
Speed: 16.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.50 V
Bin. Bits: 00011111
Count: 19
Hex Value: 0x0000
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 160
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:35
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0001
Voltage: 12.50 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:25
Freeze Frame:
Voltage: 12.63 V
DU
Temperature: 32.0°C
RPM: 1933 /min
Speed: 16.0 km/h
Speed: 16.0 km/h
Count: 0
Address 53: Parking Brake Labels: 3AA-907-801.clb
1 Fault Found:
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 160
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:24
Freeze Frame:
Voltage: 12.50 V
Count: 105
Speed: 14.0 km/h
Hex Value: 0x1260
Hex Value: 0x0004
Hex Value: 0x0101
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 029600000B000200
Shop #: WSC 00028 028 00020
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_SK46.rod
VCID: 377AB3F38E5E2386AC-8062
Subsystem 1 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H04 0012
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H04 0012
Coding: 230000
1 Fault Found:
13705987 - Databus
U1123 00 [137] - Received Error Message
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 5
Reset counter: 160
Mileage: 63219 km
Date: 2022.01.26
Time: 10:35:23
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AJ
Component: Batt.regelung H51 1634
Serial number: 260413F1000176
Coding: 330F1159
Shop #: WSC 61887 000 1048576
VCID: 71EE4DEBA8BABDB6A2-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 172
Reset counter: 194
Mileage: 54760 km
Time Indication: 0
Date: 2015.08.01
Time: 08:17:42
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3AE 907 441 HW: 3AE 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525 PA8J344242
Coding: 0020006
Shop #: WSC 00028 028 00001
VCID: 72EC42E76DBC86AE5B-8026
3 Faults Found:
02203 - Audio / Video Input 1
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 10
Reset counter: 192
Mileage: 62150 km
Time Indication: 0
Date: 2016.05.06
Time: 15:19:07
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 5
Reset counter: 192
Mileage: 62543 km
Time Indication: 0
Date: 2016.05.21
Time: 16:57:24
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
02283 - Video Connection to Output [End Unit]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 192
Mileage: 62543 km
Time Indication: 0
Date: 2016.05.21
Time: 16:57:48
Freeze Frame:
Term 15 On
Reverse ON
Count: 3
End-------------------------(Elapsed Time: 04:39)--------------------------
2 Faults Found:
Freeze Frame:
Freeze Frame:
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 1
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:25
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 159
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:25
Freeze Frame:
Speed: 16.0 km/h
Hex Value: 0x0000
Voltage: 12.50 V
Bin. Bits: 00011111
Count: 19
Hex Value: 0x0000
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 160
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:35
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0001
Voltage: 12.50 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:25
Freeze Frame:
Voltage: 12.63 V
DU
Temperature: 32.0°C
RPM: 1933 /min
Speed: 16.0 km/h
Speed: 16.0 km/h
Count: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 160
Mileage: 63219 km
Time Indication: 0
Date: 2016.06.18
Time: 10:35:24
Freeze Frame:
Voltage: 12.50 V
Count: 105
Speed: 14.0 km/h
Hex Value: 0x1260
Hex Value: 0x0004
Hex Value: 0x0101
Coding: 230000
Coding: 230000
1 Fault Found:
13705987 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 160
Mileage: 63219 km
Date: 2022.01.26
Time: 10:35:23
Coding: 330F1159
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Reset counter: 194
Mileage: 54760 km
Time Indication: 0
Date: 2015.08.01
Time: 08:17:42
Coding: 0020006
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 192
Mileage: 62150 km
Time Indication: 0
Date: 2016.05.06
Time: 15:19:07
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 192
Mileage: 62543 km
Time Indication: 0
Date: 2016.05.21
Time: 16:57:24
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 192
Mileage: 62543 km
Time Indication: 0
Date: 2016.05.21
Time: 16:57:48
Freeze Frame:
Term 15 On
Reverse ON
Count: 3
My question are:
Thanks
