Lots of error code on a B7 2013 2.0TDI
  • Lots of error code on a B7 2013 2.0TDI
    Hi Guys
    Hope everyone doing well.
    I need some help with my B7 2013 2.0TDI (63,000Km)
    This morning I was parked in the driveway without handbrake and engine ON.
    I shift from P to D and the car did a jerk...after a lot of lights and error message come up on the dash.
    1)Tyre Pressure fail
    2)Error AFS (adaptive corner light)
    3)ABS Error
    I also notice that the push button for the ASR is not working.
    I have the VAG cable so I connected and scan the car. The follow are the codes:
    Chassis Type: 3C (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 3C 42 44 46 4C 4F 52
    53 55 56 61 62 6C 72 77 A5
    VIN: Mileage: 63270km-39314miles
    Address 01: Engine (J623-CFGC) Labels: 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 RG HW: 03L 907 309 AE
    Component: R4 2,0L EDC H28 4679
    Revision: 41H28--- Serial number: VWZCZ000000000
    Coding: 001D0012042501080000
    Shop #: WSC 00028 028 00211
    ASAM Dataset: EV_ECM20TDI01103L906018RG 003005
    ROD: EV_ECM20TDI01103L906018RE.rod
    VCID: 0008182F9B10A43E5D-8054
    2 Faults Found:
    5290 - Throttle Actuator Control Circuit
    P2100 00 [032] - Open Circuit
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    5305 - Throttle Position Sensor (G69)
    P0123 00 [032] - Signal too High
    Freeze Frame:
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-927-770.lbl
    1 Fault Found:
    18255 - Please check DTC Memory of ABS Controller
    P1847 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 4
    Reset counter: 1
    Mileage: 63219 km
    Time Indication: 0
    Date: 2016.06.18
    Time: 10:35:25
    Address 03: ABS Brakes Labels: 3AA-614-109.clb
    2 Faults Found:
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 1
    Fault Frequency: 4
    Reset counter: 159
    Mileage: 63219 km
    Time Indication: 0
    Date: 2016.06.18
    Time: 10:35:25
    Freeze Frame:
    Speed: 16.0 km/h
    Hex Value: 0x0000
    Bin. Bits: 00000000 00000000
    Voltage: 12.50 V
    Bin. Bits: 00011111
    Count: 19
    Hex Value: 0x0000
    01325 - Control Module for Tire Pressure Monitoring (J502)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 160
    Mileage: 63219 km
    Time Indication: 0
    Date: 2016.06.18
    Time: 10:35:35
    Freeze Frame:
    Speed: 0.0 km/h
    Hex Value: 0x0001
    Voltage: 12.50 V
    Bin. Bits: 00011111
    Count: 191
    Hex Value: 0x0000
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    1 Fault Found:
    01316 - ABS Control Module
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Fault Status: 11101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 159
    Mileage: 63219 km
    Time Indication: 0
    Date: 2016.06.18
    Time: 10:35:25
    Freeze Frame:
    Voltage: 12.63 V
    DU
    Temperature: 32.0°C
    RPM: 1933 /min
    Speed: 16.0 km/h
    Speed: 16.0 km/h
    Count: 0
    Address 53: Parking Brake Labels: 3AA-907-801.clb
    1 Fault Found:
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 160
    Mileage: 63219 km
    Time Indication: 0
    Date: 2016.06.18
    Time: 10:35:24
    Freeze Frame:
    Voltage: 12.50 V
    Count: 105
    Speed: 14.0 km/h
    Hex Value: 0x1260
    Hex Value: 0x0004
    Hex Value: 0x0101
    Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
    Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
    Component: AFS-ECU H04 0111
    Revision: -------- Serial number: --------------
    Coding: 029600000B000200
    Shop #: WSC 00028 028 00020
    ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
    ROD: EV_HeadlRegulVWAFSPt_SK46.rod
    VCID: 377AB3F38E5E2386AC-8062
    Subsystem 1 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
    Component: LeiMo links H04 0012
    Coding: 230000
    Subsystem 2 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H04 0012
    Coding: 230000
    1 Fault Found:
    13705987 - Databus
    U1123 00 [137] - Received Error Message
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 160
    Mileage: 63219 km
    Date: 2022.01.26
    Time: 10:35:23
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 7N0 907 530 AJ
    Component: Batt.regelung H51 1634
    Serial number: 260413F1000176
    Coding: 330F1159
    Shop #: WSC 61887 000 1048576
    VCID: 71EE4DEBA8BABDB6A2-8024
    Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
    Component: J367-BDM H07 0180
    1 Fault Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00110001
    Fault Priority: 7
    Fault Frequency: 172
    Reset counter: 194
    Mileage: 54760 km
    Time Indication: 0
    Date: 2015.08.01
    Time: 08:17:42
    Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
    Part No SW: 3AE 907 441 HW: 3AE 907 441
    Component: J772__Rearview 0020
    Revision: 00H11000 Serial number: 525 PA8J344242
    Coding: 0020006
    Shop #: WSC 00028 028 00001
    VCID: 72EC42E76DBC86AE5B-8026
    3 Faults Found:
    02203 - Audio / Video Input 1
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 10
    Reset counter: 192
    Mileage: 62150 km
    Time Indication: 0
    Date: 2016.05.06
    Time: 15:19:07
    Freeze Frame:
    Term 15 On
    Reverse OFF
    Count: 3
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 4
    Fault Frequency: 5
    Reset counter: 192
    Mileage: 62543 km
    Time Indication: 0
    Date: 2016.05.21
    Time: 16:57:24
    Freeze Frame:
    Term 15 On
    Reverse ON
    Count: 4
    02283 - Video Connection to Output [End Unit]
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 192
    Mileage: 62543 km
    Time Indication: 0
    Date: 2016.05.21
    Time: 16:57:48
    Freeze Frame:
    Term 15 On
    Reverse ON
    Count: 3
    End-------------------------(Elapsed Time: 04:39)--------------------------
    My question are:
    1) I try to reset the codes, but the errors are come back. Very interesting to know why some error from 2015 and 2016 are still come up during the scan?
    2) The tyre pressure monitor is the "indirect" one that use the ABS sensor....Can possible be just a faulty sensor that bring up all these errors?
    If anyone can help I will really appreciate.
    Did you have a battery replaced in 2016? Lots of communication errors in 2016 so it would seem either your car received a new battery or perhaps some other work was carried out that may have either unplugged the battery or other electrical connections.
    2015 Audi SQ5 - SOLD
    New car incoming...
      I think so.... I think I replace the battery.
      But they shouldn't reset ?
        Not unless you reset them. I would get the errors reset/cleared and go from there.
        You already have a list of all the old errors so clear them and see if any come back again.
        New car incoming...
          With the VCDS I did clean codes, but the older one they still in memory.
          Do I need use a different procedure?
