Hey guys,
So as many of you know, this car has no service history at all (apart from my own).
What appears to be at random, the car has started to make this noise from what appears to be the right hand side of the motor (near the end of the video it is more prevalent).
Just wanting opinions on if this sounds normal, the car isn't at full temp here but it's definitely warmer as I was driving around 30 minutes before.
I've checked the timing chain via VCDS with blocks 208 (-3.0) and 209 (-2.0) as per below (this was around a week ago). This was in the past (Sixish month ago) -3.0 and -4.0 so this seems ok from what I've read but I suspect it could still be bad or potentially the tensioner.
Have had almost all fluids (except coolant, that's to be done soon) changed since I've owned it. Last oil change was around 2,000k's ago with 5w-30 Fuchs. I'm thinking a 5w-40 may be good, but is this just hiding the issue?
Any suggestions are welcome, I'm getting no loss of power and no timing related or engine codes at all. The only codes that I've seen (and not fixed) are the parking sensors which is obviously irrelevant to the issue. I will do another scan later today or tomorrow to confirm however.
