Coming home is set by the factory to be activated manually by pulling the indicator stalk back briefly when you remove the keys from the ignition although if you want, you can set it via VCDS to work automatically by unticking one of the bits (Byte 12 bit 2 in the newer Tiguans with the 30 byte #9 BCM) Leaving home as you would expect, can only be set automatically and hence you need a switch which includes the "auto" setting
Tiguan VCDS Coding Options
Last edited by Bambazonke; 21-07-2014, 06:42 AM.MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
Mods: VCDS tweaks |
Hi there, i have recently put in some "error free" LED lighting for the licence plate on my 2015 Tig R. The error lighting still show up, how do i fix it of disable it via VCDS? I notice you did have some screen shot posted, but is not visible anymore.....
Evilz.
Disable additional licence plate bulb monitoring @ Bit 6
Note: Will get rid of the stubborn "bulb out warning light" received even with error-free LED bulbs2015 MY15 Tiguan 155TSI R-Line ~ Pan roof /Bi Xenon's AFS /RNS510 /RVC Plus /DSG7 /APR Carbonio Stage II intake kit, IC, Oil CC, Boost tap /Neuspeed charge & discharge pipes /Neuspeed & ECS end links/ VWR BBK & SS lines/ H&R sway bars /APR ECU Upgrade /HP DSG DQ500 Tune/R8 Coil Packs/GFB DV+ /ABT kit!(FAMILY CAR)
2014 F30 328I (ME CAR)
2011 E46 330CI (SOLD)
For the licence plate monitoring - Module 9 and then Bit 6TIGR
2017 162TSI R-Line Tiguan - Tungsten Silver | DAP | APR Stage 1 Build thread: https://goo.gl/YNgixR
2015 155TSI R-Line Tiguan - Build thread: https://goo.gl/sEqISR
which vcds version are you using? Im using version 14.1 atm, under module 9 i can't find bit 6........ Any chance of posting some snap shots would be greatly appreciated.2015 MY15 Tiguan 155TSI R-Line ~ Pan roof /Bi Xenon's AFS /RNS510 /RVC Plus /DSG7 /APR Carbonio Stage II intake kit, IC, Oil CC, Boost tap /Neuspeed charge & discharge pipes /Neuspeed & ECS end links/ VWR BBK & SS lines/ H&R sway bars /APR ECU Upgrade /HP DSG DQ500 Tune/R8 Coil Packs/GFB DV+ /ABT kit!(FAMILY CAR)
Sorted...... it actually bit 18..... activate License Plate Lighting w/o Pulse Width Modulation (PWM) [LED Lighting].2015 MY15 Tiguan 155TSI R-Line ~ Pan roof /Bi Xenon's AFS /RNS510 /RVC Plus /DSG7 /APR Carbonio Stage II intake kit, IC, Oil CC, Boost tap /Neuspeed charge & discharge pipes /Neuspeed & ECS end links/ VWR BBK & SS lines/ H&R sway bars /APR ECU Upgrade /HP DSG DQ500 Tune/R8 Coil Packs/GFB DV+ /ABT kit!(FAMILY CAR)
Is it just me, or have all of the images in the early part of this thread disappeared?Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
Does anyone know if it is possible to set up my late-2010 Tiguan to use dimmed halogen projectors as DRLs? I can set it up so the dipped lights work or the fog lights? I can also presumably use a separate light, but these would have to be installed.
While on the subject, when I have the dipped lights being used as the DRL, is there any reason why the status would tell me to check both the left and right DRLs and show a warning light in the instrument cluster?Last edited by arcadelt; 24-01-2016, 10:19 PM.Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
Originally posted by eciuj View PostWhat is everyone here using? I'm not prepared to pay several hundred dollars for the Ross-Tech, but also don't want to waste time and money on cheap eBay cables that may not work.
Cheers.Tiguan 2.0TSI 180 (132), DSG Promotech stage 1 260hp/410Nm+DSG tune
Originally posted by arcadelt View PostIs it just me, or have all of the images in the early part of this thread disappeared?
When they stopped being free, the b@$t@rd$ pull all the pics off.
If somebody wants to re-post them up again, I can give you all the photos.
But you would need to work out what is what!
No longer have the Tig and have moved to another stable.MY11 Tiguan 147TSI (SOLD)
Originally posted by aussietig View PostUnfortunately original images were posted up using Imageshack.
No longer have the Tig and have moved to another stable.Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
