Originally posted by Ryan_R
View Post
Flappy paddles steering wheel in Tiguan.
+1. Although I love my flappy paddles I use them a whole lot less now that I have the DQ500 DSG software upgraded. I could actually live without them it's that good now. But I do like my flat bottom wheel... so may as well get one with paddles
Probably his way of bookmarking threads!!Originally posted by Transporter View PostWhat reference?
Please explain.
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
The sTig likes the idea of this thread & has 'filed it away' for a future mod of his own. Honestly, Miro...Originally posted by Transporter View PostWhat reference?
Please explain.Current: MY18 TRANSPORTER CrewVan, Indium Grey
Then, don't do that. You can mark what interests you in the browser on your PC and even in the smartphone. Imagine, we all would be doing it.
Sent from my GT-I9505Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
There's a brand new flat bottom flappy paddle steering wheel for sale in Qld if anyone is interested: [QLD] Golf R Flat Bottom Steering Wheel w/ DSG Paddles + Airbag
Yes this will be a direct swap. Once you get the steering wheel fitted you'll need to get someone with VCDS to enable the paddles.Originally posted by Safferbogun View PostTigger73 I have contacted the guys and made a deal with him, will this be a direct swap out with my 2012 Tig 155? Also do I need anything extra to get the flappy paddles working?
MFSW with flappy paddles in 2008 Tiguan Tiptronic
I did this mod, added Mk6 MFSW with flappy paddles to a 2008 Tiguan TDI with standard auto ("Tiptronic", not DSG). Note this car is based on Mk5 electronics compared to the newer Tigs discussed here (2010+)
COMMENTS ON MY EXPERIENCE- GLI wheel with red stitch and silver trim AUD500 from Mexico, control module AUD60 from China, landed.
- The SW control module had to be replaced to support LIN2.0 which the newer MFSW buttons use.
- The 'flappy paddles' work great even on the TipTronic. No coding of the Auto Trans needed - just need to code the new steering wheel module to "Tiptronic paddles present" as described by OP.
- 1K0-953-549-CH is the correct new steering wheel control module. My old one was BG.
- The actual swap is easy, just make sure you have all the tools beforehand!
- Hardest part was removing the old steering wheel control module: the clips are fiddly. Study your new module to see where you have to insert two thin metal sticks (like drill bits or allen keys) to undo the clips. Once you know how, it's easy.
- Be careful aligning the new control module with the pins as you push it in it's place - you don't want any bent pins!
- I didn't disconnect the battery, and nothing blew up in my face. Lucky me.
- I activated BAP protocol in my RNS510 so that the left side MFSW buttons control vol/track without having to be in the "Audio" menu on the old red-screen MFD. Of course this turns off the nav and audio menus in the MFD because the old MFD only speaks DDP not BAP.
SUGGESTED TOOLS
You don't want to take the airbag off your only car only to discover you need to drive to the shops to get the correct tool to remove the wheel (ask me how I know)*- 12mm XZN/triple square bit ($20 off amazon incl shipping)
- Make sure you have the right size drive handle, some 12mm XZN bits are 3/8" drive and some are 1/2" drive
- Small TORX bit to remove the SWCM, it's like a T5 or T6 - or you can use a small flathead screwdriver if needed.
- A torque wrench is suggested to tighten the bolt up again, $99 at REPCO (50Nm/36ft.lb is the spec I read on the 'net)
ADAPTATION WITH VCDS
Going for a drive didn't clear the ABS and Steer Assist warning lights from my dash, requiring the annoying "Basic Settings" procedure which is described really well on Ross-Tech website. This is due to the control module swap.
- You need a nice open space like a shopping centre carpark.
- Process took me the good part of an hour, the wheel is really hard to turn without steer assist!!
- Need laptop with VCDS cable attached to the OBD port as you drive
- Both the ABS brakes module and Steer assist module need the "Basic settings" done.
- After doing the procedure on Ross-Tech website, the lights still stayed lit
- The final step was to open "Measuring Blocks" to block 4 in the brakes module, which showed a constant "0" for steering angle, and then drive around the carpark slowly for two minutes, then suddenly the steering angle started reading a value between -2' to 2' when straight, and all the lights went out
Result: the wheel feels great and works great.
*NB: I drove the car without the driver side airbag attached, and this resulted in an error in VCDS under airbag module saying "Airbag igniter module - value exceeds limit" - cleared with VCDS after the install and all good. Interesting to know the system does actually monitor the status of the igniter - I assumed it was just an all-or-nothing "FIRE!" signal, as there are only 2 cables attached to the igniter (plus ground I suppose).- 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
- 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
Not my cup of tea personally, but might be for others?
Flappy paddle extensions
Looks rather sharp and something out of a Batman movie!
Might just take some fingers off on track days.
MY11 Tiguan 147TSI (SOLD)
I see what they were trying to do... but I don't think they've pulled it off
I had the standard wheel style with the paddles but replaced it with a flat bottom wheel because I like the look.
Prior to the install, my normal wheel had a slight deviation to the left (alignment required), however, after installing this new wheel it's a lot more noticeable it's quite to the left. I made sure it was straight when I installed it. Is it possible to crook it to the left more than normal when installing it, or do the guides prevent you from installing it anyway but the way it was installed? I know I just installed it, but I didn't bother to check and I don't want to take it all apart again to straighten it up if it's not do-able.
On another note, I have a spare standard style wheel with paddles available if anyone is looking.MY17 206 R-Line Passat Sedan, Pure White, Sunroof | Spectune STG1 | VWR 600 Intake, TMD, Inlet Elbow | Res Delete
MY 13 Tiguan 155TSI | Pepper Grey | DSG | Leather | RVC | RNS510 | ACC | 18" New York Wheels -SOLD
Perhaps you put it on the splines offset by one. You'd have to take it off and put it around one notch and see if that doesn't put it the other way. This may also be able to be fixed through a wheel alignment if it's not too far out.Originally posted by Wynnston View PostI had the standard wheel style with the paddles but replaced it with a flat bottom wheel because I like the look.
