Originally posted by tigger73
View Post
Flappy paddles steering wheel in Tiguan.
Thanks. Did you order from there? I've heard some issues about shipping the airbags by air because the igniters are deemed to be hazardous explosives??? What was your experience?MY2013 VW CC V6 4Motion: Debadged, Eibach Pro Springs, Gloss Black 19' VMR708 Wheels, Window Tint, Tail Tint, Matt Gray Metallic Wrap, Gloss Black Wrap on Roof, Mirrors and Chrome, PlastiDip Grill & Badges
If you use Chrome, you can get it to auto-translate. You sorta get some pidgin English translations but good enough nevertheless.Originally posted by tigger73 View PostIf you're good at reading Russian, have a translation program, or just want to click until you get the right part then here's an ETKA link: Èíôîðìàöèÿ îá àâòî - ETKA-online, îíëàéí ïîäáîð äåòàëåé ïî íîìåðó
.Cheers, Abuthen.
Tiguan 132TSI Pacific MY13
Candy White - 6Sp Tiptronic - Comfort Pack - Park Assist 2 - Panoramic Sunroof - Fog Lights
Finally decided to install my paddle shift steering wheel, very easy!
Luckily i didn't have to change my airbag as i had the same steering wheel but without paddles and different shape.
[/IMG]
Only problem i'm having is getting paddles to work.
Got the pop up menu below and not sure what to do.
[/IMG]
Original coding below
[/IMG]
Anyone can help??MY10 Tiguan 125TSI /APR Stage 2
Go to long coding and enable the option. Just need to tick the option
coding
Hi Tigger73, when I press coding it comes up with screen i took a picture of, cannot go into long coding or any other options.Originally posted by tigger73 View PostGo to long coding and enable the option. Just need to tick the option
I think I have to do it manually?MY10 Tiguan 125TSI /APR Stage 2
Maybe I have to change the coding? Originally the coding was 0001132. Do I change it to 0001232 because now I have triptronic? Or which one do I change to enable paddles?Originally posted by tigger73 View PostGo to long coding and enable the option. Just need to tick the option
RegardsMY10 Tiguan 125TSI /APR Stage 2
Hi thereOriginally posted by Suffolk View PostFinally decided to install my paddle shift steering wheel, very easy!
Anyone can help??
Note how it says 0xxx?xx just above the section regarding tiptronic (paddles)
So the ? is the digit to change (3rd from right)
Yours currently is 1 (00011132)
"1 OR 5" = No Tiptronic and no PTT
You want to change it so that you do have Tiptronic and no PTT
So change it to 2
New coding is 00011232
Job done
Good to hear you got it going. With mine it gave the option for long coding (same as AussieTig in post #2). Good to see that you got it sorted. Enjoy your flappy paddles!!!Originally posted by Suffolk View PostCoding is 0001232. No long coding for this one. Ryan_R is correct! Thankyou
Job Done
Baboo,
Good thing about paddles is that they also work in D. Press + on paddles and it's activated. Press OFF, and you will go back
to Auto.
Had to explain it to the wife just in case she pressed one of the paddles and didn't know what to do. Great upgrade, especially if you don't
Need to buy another airbag.MY10 Tiguan 125TSI /APR Stage 2
Actually it will revert to D after about 20-30 seconds. Same if you're driving in S and hit the paddles to upshift it will revert in 20s and downshift back...Originally posted by baboo View PostSuffolk,
does the flappy paddles work when you just leave in D? or do you have to shift to Tiptronic mode before you can use the paddles
I use my paddles 90% of the time.
