Mk2 Tiguan Tuning
  • #91
    Originally posted by Melbourne_Tiggy View Post
    Hi Inasnt, the performance meter on the Tig will max out at 162 kw (unfortunately). In terms of stage 1 boost, I haven’t paid to much attention to this but it does starts to head towards that 30 psi mark.
    I spoke to Simon at Peerless and he does sound knowledgeable and if he is close and can support you, that sounds like it ticks all the boxes. I went to Allan in VW Park for the same reasons.
    I have also been speaking with Alex from underground performance and he is very knowlegable and has custom tuned a few 162 TSIs, I think stage 1 puts out 177kw at the wheels. So that is another potential option.
    I talked with Peerless a few weeks ago and they said that the RHD downpipe is not available at the moment for stage 2..
    APR website says with Stage 2 the APR Exhaust Crackle can be added at no extra cost. Stock GTI vs Stock Tig 162 exhaust seems to be very different as the Tig is very quiet even at full throttle even in sport mode. Assuming the 'electronic flag' in the exhaust is not on the Tig which make it so quiet all the time? Wonder if the 'Exhaust Crackle' just a downpipe upgrade with stage 2 on tig will be as effective as on the GTI..
    Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
    • #92
      Hi, there is a DP available for Stage 2 Tig it is the same as the MQB golf R (Part DP something 21) I booked in about 3 weeks ago to get it installed but unfortunately the stage 2 file has not been created for our Tig yet. I have ordered the file to be created with crackles and pops by APR USA, I haven’t had a chance to follow up, but it might be available now. So hopefully that saves everyone some waiting time.
      I’m thinking of doing a IS38 or a BT upgrade, as I’ve been told it’s a few hours more labour than the DP job, as the old DP has to come out anyway.
      There are a few choices, what looks interesting are the IS20 and IS38 hybrids. Snailturbo (the brand that Underground uses) seems to be getting some ridiculous numbers are using these. I think. The IS20 snailtubro with custom tune was putting down 270 Kw atw.
      VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
      • #93
        Oh man I can't wait to see some videos of this Tig when you get all this!!
        Sent from my SM-N950F using Tapatalk
        • #94
          Wouldnt it be the GTI downpipe?
          When you getting the works done?
          I have been talking with etuners about custom ecu and dsg tune. For DSG adjusting clamping pressure, launch control, shifting points, torque limits and delete the auto kick down in M mode. Bit more pricey tho at $1600
          • #95
            Hi Inasnt,
            The GTI dp is for a front wheel drive, we have awd and so the bends are a bit different so we need the Golf R awd dp.
            Thinking about pulling the trigger over the next few months, I’m keeping an eye out for an IS38 with Low kms (not first gen- which had issues).
            I spoke with Gordie from etuners a while back and they have been getting some great feedback for their tunes. They have a dyno in Melb and can do a before and after run (around $100). Let me know how you go.
            • #96
              Hi Inasnt,
              CTS MK7 R Downpipe fit?
              • #97
                Went to see Etuners in Dandenong today to look at options. They do a baseline dyno run then send the details with mods to their head office in Greece. Within 5-10 mind revised tune is sent back and loaded then dyno run again, process is repeated until you and they are happy with the curve and parameters.
                I am used to the dyno operator doing the tuning on the spot, but having an expert in Greece looking at the live data is essentially the same thing.
                MK7 GTI/R CTS Intake and MK7 R Downpipe fit. There is so much more room in the engine bay than a GTI/R to get to the intake and downpipe, can actually see all the bolts.
                As intake is not needed for stage 1 or 2 tunes might put a K&N drop in filter in which is around $85. Might be too much noise with the CTS I take I was thinking.
                Downpipe is $1100, $350 install. Around 3k for stage 2 with dsg tune for around 250kw@ engine real custom tune power.
                Looking to have it done in 2 weeks time
                • #98
                  Keen to see a video when you have done it!
                  • #99
                    Super exciting!!!!! Let me know how you go. It would be good to post the dyno runs before and after. Do you mind asking Gordie whether the 162TSI is running a DQ380, 381 or 500?
                    • Originally posted by Melbourne_Tiggy View Post
                      It is the DQ500. The DQ380/381 has only just come out in the last year in Mk7.5 R (and Arteon).
                      - Tigger73's 125TSI Build
                      • Originally posted by tigger73 View Post
                        Whats the main differences?
                        • Originally posted by INASNT View Post
                          DQ500 has higher torque limits.
                          I’m not sure if there’s differences in gear ratios.
                            I was under the impression that the Q380/381 had the high torque limits as its the newest version?
                            • The DQ 250 6 speed is 380nm rated
                              The DQ381/380 is 420nm rated
                              The DQ500 is 480 or 500nm rated
                              2017 Golf Alltrack 135tdi All options
                              • Just collected my MY18.5 Tiguan 162TSI last week
                                Looking to get my car tuned soon...
                                Questions I have:
                                Are there other good tuning software besides APR?
                                Any recommended tuners in Brisbane?
                                I only have around 300kms on the odometer - is this a right time to tune, or is it too early?
                                VW Tiguan 162TSI R-line 2018 - IS38 + DP + CTS inlet + Tarmac custom tune
                                Mazda 3 MPS 2010 - gtx2867r, fmic, 3.5in intake, hpfp, 3in downpipe, Cobb accesport, PD Tune
