Picked up my 162tsi with all options in white Friday.
Going to get Peerless Automotive to do the APR tune after around 5,000km.
Given the APR claims of around 230kw @engine for stage 1 vs 250kw @engine for stage 2 which needs AWD down pipe wondering if the stage 2 is actually worth it....
For most cars on the road picking up that 20kw for the cost of a down pipe id insanely good value. It just doesn't seem as such because of the massive gains from stage 1 - which really are unparalleled against most cars.
Hi INASNT You could go APR stage 1 first and see whether that power is enough for you. Stage 2 software is a free upgrade when you buy the APR MQB AWD downpipe, so you can build it incrementally. I will prob get the down pipe soon and will use the Dragy performance monitor to measure the 0-100 times.
VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
Stage 2 generally is more about giving you a nice big fat torque curve. There's a bit more at the top end in terms of power but it's the mid-range torque increase you'll notice most.
A little off topic: 2016 Scirocco R, stage 1, 205kwaw
isn’t the Scirocco FWD only?
Yes it is FWD. Makes for interesting driving getting all that power down through the front wheels. Is better when rolling rather than from a standing start otherwise traction control just kicks in. AWD in a Tiguan is definitely an advantage off the line and in the wet.
a bit more on topic: how much more is the IS38 upgrade over the downpipe?
You'd want to do both IS38 and DP but I'd budget on ~$5k for turbo, exhaust and tune. But don't quote me on that - better to talk to your local tuner and get a price including fitting.
Hi Ewok
A CTS turbo IS38 (on sale at the moment) is just over $2000 landed, excluding any local/import taxes. Tim from Dub Addiction also sells IS38s for $2499 in Melbourne. The APR software for an IS38 can work with the OEM downpipe, however more power can be achieved with an after market down pipe. You might need to contact a dealer about the cost of the IS38 software.
Hi Ewok
Hope that helps!
thanks! That gives me a pretty good idea about costs.
I am thinking of using Peerless for the APR tune as they are close to my place.
On the weekend I used the performance meter to see how much boost (psi) it runs stock. According to the performance meter at full throttle it runs around 15psi. The gauge shows 30psi but the atmospheric absolute pressure is 14.69psi so need to minus this.
Interested to see how much boost stage 1 or 2 would run.
Hi Inasnt, the performance meter on the Tig will max out at 162 kw (unfortunately). In terms of stage 1 boost, I haven’t paid to much attention to this but it does starts to head towards that 30 psi mark.
I spoke to Simon at Peerless and he does sound knowledgeable and if he is close and can support you, that sounds like it ticks all the boxes. I went to Allan in VW Park for the same reasons.
I have also been speaking with Alex from underground performance and he is very knowlegable and has custom tuned a few 162 TSIs, I think stage 1 puts out 177kw at the wheels. So that is another potential option.
I saw the recent FB post, nice numbers. Big lump of torque down low!
