Originally posted by petemac110
View Post
No more stop/start.
Well aware as I did about 36 mods to my Tig but none were performance ( apart from the Audi mod) or suspension mods. Merely pointing it out so if anyone buys it without reading they will be aware. As I said most is able to be done without it . My Kamiq has the ability to do all that. without anything to help it and the Cupra etc are all built on virtually the same platform so should be similar. Also am a bit shy on inserting cables where they may not be the best place to go. If you can adjust the electronic parameters fine but sticking cheat cables in is a bit off in my book2021 Kamiq LE 110 , Moon White, BV cameras F & B
Yep, read the bit re "Off road use only", but that's just a disclaimer to try and save them, but not something that'd work with a good lawyer. Anyways ......Originally posted by Hillbilly View PostWell aware as I did about 36 mods to my Tig but none were performance ( apart from the Audi mod) or suspension mods. Merely pointing it out so if anyone buys it without reading they will be aware. As I said most is able to be done without it . My Kamiq has the ability to do all that. without anything to help it and the Cupra etc are all built on virtually the same platform so should be similar. Also am a bit shy on inserting cables where they may not be the best place to go. If you can adjust the electronic parameters fine but sticking cheat cables in is a bit off in my book
Hiya hillbilly - I'm with you re prefer to do the tuning via coding/using OBD11, BUT, I've found out the hard way that what works with VW doesn't always work the same with the Cupra, even though it's made by the same mob.
It's frustrating as hell, and I've tried multiple options to solve my issues and still not easily getting anywhere.
I could just also turn it off each time I get in the car, but that's not the way I like it ....2024 CUPRA Leon V Tribe Edition
Biggest problem is since they changed things as I said about the camera model and probably other stuff, things have been much harder to do, to the extent I have given up on most stuff. Im probably going to lose my license in a few months due to one eye going very bad so not worrying any more.Originally posted by Michael_B View PostYep, read the bit re "Off road use only", but that's just a disclaimer to try and save them, but not something that'd work with a good lawyer. Anyways ......
I could just also turn it off each time I get in the car, but that's not the way I like it ....2021 Kamiq LE 110 , Moon White, BV cameras F & B
I HATE the fact that some people cant/dont ship worldwide.Originally posted by Michael_B View Post...
Seat Leon - Disable Start-Stop, keep last Drive Mode and more
– Burteq
You can get either the Start/Stop only or other features, and I've also seen the Aliexpress versions.
To ship to Aus via UPS is A$193
.Originally posted by Hillbilly View PostI'm probably going to lose my license in a few months due to one eye going very bad so not worrying any more.
Me too!! Sorry to read about your problem!
DonPlease don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
Ha ha Yes, Drove Taxis on and off for 20 years and City buses for 10 years,in two countries. Also have owned over 30 different cars. Meanwhile back to fixing Stop Start LOLOriginally posted by petemac110 View PostThat's a LOT of driving under your belt!!!2021 Kamiq LE 110 , Moon White, BV cameras F & B
Sorry to hear Hillbilly, that’s not fun!
On the subject of stop/start defeat cables I can vouch for the $15 AliExpress job on my MY23 Tig R.
It’s a memory cable so once the s/s is turned off it doesn’t need switching again, but can be switched back to active.
Shop was Enjoyssa on AliExpress.
I'm waiting on mine at the moment, but the $47 one linked above. Not keen on trying to install the multiple separate wires and the single connector seemed much easier.Originally posted by GolfRWag View PostSorry to hear Hillbilly, that’s not fun!
Car is off to a workshop on Tue morning to see what they can do re the fault code issues I have.
Fingers crossed !2024 CUPRA Leon V Tribe Edition
Should have known that it wouldn't work properly.Originally posted by Michael_B View PostI'm waiting on mine at the moment, but the $47 one linked above. Not keen on trying to install the multiple separate wires and the single connector seemed much easier.
Fingers crossed !
A right PITA to fit, it memorised the start stop but not anything else and now has caused faults with the rear sensors.
GRRRRRRRR
Why didn't I learn after my brake shennanigans ....
