Tiguan IS38 and Big turbo upgrades
  • #91
    Newer, modern cars all run EGT, IAT, Baro, Wideband O2, Fuel temp sensors, multiple knock sensors, etc. which enables multiple dimensions to both the ignition and fuel tables. Thus if you're smart enough to interpolate the tables for either end of the spectrum then you'll be fine.
    Back in the old days yes you would need a map per location however these days there is simply no need with varying dimensions applied on maps with each additional sensor.
    Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
    Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
    www.nhbautomotive.com.au
    • #92
      Originally posted by Melbourne_Tiggy View Post
      To be clear it’s not a single generic/standard map, you can select a octane/ethanol specific map for most octane types 95/98/104/e85, depending on your model. Being a global distributor and tuning thousands of cars a year, with proper R&D to get reliable and consistent power, mastery of various ECU types makes APR a well regarded tuner.
      Not withstanding all that you can go get a custom tune with Underground Racing, Etuners, Etuners Motorsport or other generic tuners like Revo, GIAC or even piggy backs like Race Chip or Burger Motorsports.
      In terms of being a conservative tunes, APR holds a number of world record 1/4 mile times for the VW and Audi platforms, so I wouldn’t call that conservative.....
      Not a criticism but it would be conservative compared to a custom tune. They have got to cover their arses and make a reliable map to suit all kinds of conditions for a given fuel type. Thanks for that info though.
      • #93
        Yeap, they won’t be pushing engines to the extremes. I for one love the fact that it’s going to be reliable and not cause me any headaches. All the best with your research, perhaps post a review of the tune that you end up with to benefit the community.
        VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
        • #94
          Conservative wouldn't be the right term however they wouldn't being putting much timing in to be knock limited.
          Then again who knows what these tunes do, could be purely more boost and that's it or same timing more boost and spray more fuel to suppress knock.
          I've been trying to find software and hardware that allows me to do my own tuning however haven't been close to anything.
          BMW platform you have a few options such as MHD combined with Tuner Studio.
          • #95
            Correct.
            Here's a recent comparison between the latest revision Stage 2+ APR tune and a RD Technik custom dyno tune on the same car, same hardware.
            - Tigger73's 125TSI Build
            • #96
              Originally posted by tigger73 View Post
              Correct.
              [ATTACH=CONFIG]40734[/ATTACH]
              Ah...the oldie but goodie EA113 front wheel drive....it would be good to see a Tig, GTI or R with a EA888 Gen 3 IS20 or IS38 comparison....
              • #97
                Just by looking at the torque produced they're running higher duty cycles to make the torque "peaky" from boost coming on hard and bleeding off.
                The rest of the power would be from timing changes.
                Would have been good to see manifold pressure overlaid too and if the ambient temp probe was connected lol
                • #98
                  This was only done recently in the last month or so. However the question about APR "generic" tune vs custom tune and the answer is that if the custom tuner knows what they're doing then they can make more power and still do it safely.
                  There's probably a bigger safety margin in the "generic" tune but an extra ~15kwaw is a decent increase and your bum dyno would definitely feel it. It's similar sort of increase as going from stage 1 to stage 2.
                  • #99
                    Different tuners have different ways they go about tuning for sure.
                    It's always what you as a customer are going to be happiest with and there's a range of factors why people go one way vs. another in terms of tuning. Quite often it's not about the peak number but more about service, ongoing support, future mods and ability for the tuner to accommodate, etc.
                    But nobody would usually complain with a few extra kwaw
                    • Originally posted by tigger73 View Post
                      In your example that is obvious in the graph for a EA113. I would be interested to see on other modern MQB engines in particular what the differences are for custom tuners vs the global tuners are. At the end of the day, as more people make decisions to tune and that information is published and tested by consumers hopefully this helps others make informed decisions.
                      • Originally posted by Dose Pipe Sutututu View Post
                        You could be the next star tuner for the V Dubs.....we just need to find you a tuning studio. My brother has a 335 N54 TT and uses Wedge Performance for tuning via MHD. They start with a base tune and then customise it for the mods on the car. It definitely is bang for bucks, being a couple of hundred bills, and is definitely the way to go as he has mastered the platform. If you could do that for us and the VW community that would be much appreciated
                        • Originally posted by Melbourne_Tiggy View Post
                          The hardest thing is getting decent comparison data. It's a lot harder than you'd think. Best way is to organise a dyno day and get a bunch of similar cars with a range of mods and get them all run back-to-back on the same dyno under the same/similar conditions.
                          Next best is to get a customer of one brand to swap to another and get the overlay of before/after. Not a lot of people swap tuners as there's usually not a whole lot to gain and a fair bit of pain to go through.
                            Or we could all just head to the drag strip and do some 1/4 mile runs
                              Would definitely love to be, need a new challenge! Still have a 3x cars to tune, a 1JZ GTX3076 Gen 2 swapped IS300, a S15 with a GTX2860 and Poncams, and a 180SX with N/A cams and a GTX2860 Gen1. Had the 180SX on the dyno a month ago and had fueling issues, boost leaks, etc. This is why I hate tuning these **** boxes, they're always never ready.
                              At least with these newer cars everyone does the same mods, and never half arsed as there's much more pride (then again the cost of the car does play a part).
                                Of course, I get customers to often ask me to make boost and torque as aggressive as possible where as some will request it comes on as linear as possible (generally guys that track a bit).
                                Of course the hard and fast "feels" great but on the track you're going nowhere as you're just baking tyres. I personally linear power and flat torque where as for the daily driver and for most they want head snapping action lol.
