The Official Mk7 Wheel Thread
This is a sticky topic.
  • Originally posted by wasabiz View Post
    So will mine when it comes
    Sounds promising.
    • Originally posted by Dutch77 View Post
      OZ ULTRALEGGERA HLT - REVISITED
      Specs: 19 x 8.5, ET47, weight tbc
      [ATTACH=CONFIG]11873[/ATTACH]
      [ATTACH=CONFIG]11874[/ATTACH]
      [ATTACH=CONFIG]11875[/ATTACH]
      [ATTACH=CONFIG]11876[/ATTACH]
      This GTI just looks right.
      Dutch, is this yours after lowering?
      • Originally posted by avdo_ View Post
        You should be in sales.
        This one is running at a good height, I like the color and wheels combo, and the fatter tips finish off the look at the rear.
        • VW NEW YORK
          Specs: 18 x 7, ET43, weight tbc
          Not something I've seen before.. a bit on the skinny side but technically feasible.
            VW NEW YORK
            [ATTACH=CONFIG]11877[/ATTACH]
            [ATTACH=CONFIG]11878[/ATTACH]
            [ATTACH=CONFIG]11879[/ATTACH]
            These are the standard wheels on the 147/155 TSI Tiguan, hence the weird offset for a golf.
              Yeah I was looking at getting a set chucked on the 132 I almost bought last year, so realise the width and offset are geared towards the Tig. I don't mind them on the Tig, but not sure they work on the Golf..
              • BBS LM - REVISITED
                Specs: 19 x 8.5, ET48, weight 23.4lbs/10.6kg
                Other: KW coilovers
                One day I need to own a set of LMs. And yes, this R is a show car which has been seen previously with Ferrari wheels (to match the brakes) earlier in this thread.
                  BBS LM - REVISITED
                  Other: KW coilovers
                  [ATTACH=CONFIG]11892[/ATTACH]
                  Ferrari BBK!!
                  '09 mk5 Jetta 118TSI
                  '11 C7 A6 3.0TDI
                  '11 B8 A4 3.0TDI - RIP
                  • So a while back there was a bit of a debate about a set of wheels off the internet here: http://www.vwwatercooled.com/forums/...ml#post1072606
                    These are definitely the same 'reps' here, although not the Rodas Aro I referenced which translates as wheel and rim/size..
                    Anyway here are some further pics of cars wearing the same wheels a size down - I reckon these would make a good VW design!
                    • Originally posted by popcorn View Post
                      Ferrari BBK!!
                      With OZ 'tribute' wheels to match: http://www.vwwatercooled.com/forums/...ml#post1060123
                      • MBDESIGN RV1 - REVISITED
                        Specs: 20 x 9, ET tbc, weight tbc
                        • RUFF R942
                          Specs: 20 x 8.5, ET tbc, weight tbc
                          • ENKEI EV5
                            Specs: 18 x 7.5, ET38, weight tbc
                            Not available in a 5 x 112 fitment to the best of my knowledge, therefore assume adapters used.
                            Note: not a legal fitment in Australia
                            • TSW NURBURGRING - REVISITED
                              Specs: 19 x 8, ET45, weight 20.6lbs/9.3kg
                              • VMR 710/718 - REVISITED
                                Specs: 19 x 8.5, ET45, weight tbc
                                First two pics are of 710s, last two are the 718s.
