Guy was running VWR x 8.5 ET50 on VWR springs early in this thread and said no rubbing even with load.
Dropping below ET50 would likely see some rub up front unless the camber was played with.
Should be able to go lower on offset up back as the rear guards are fairly generous on the Mk7.
Avdo was at ET44 and has no rub on stock R suspension, the Eibachs would be lower but if they do tuck the fronts a little then may be able to get away with it.
Obviously this thread does feature much more aggressive fitments than this but those cars will also feature heavily worked suspension adjustments as well.
