Kufatec module to permanently disable stop/start system
It should be working, the Kufatec products are usually reliable.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Isn't there a thread somewhere (I'm sure I saw it) where you can VCDS code out the stop-start? Adaptation of something to set operating temps (for the engine) for when the function will and wont work and then setting the threshold high enough that it never kicks in.
Thats free, thus better .....Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Also there are some mk7 vehicles like mine that won't accept the temperature codings. There is an alternative method now where you set battery voltage thresholds. concept is similar, set the low battery threshhold high enough so autostart won't kick in.
How to disable Stop/Start the easy way
Hey guys i got this module online delivered from a stockist in melb in 2 days
Just plug it in wait for the l.e.d to go out took about 5 sec with mine then start/stop disabled
To reverse just plug it back in again same procedure
Easy as no longer will start/stop **** me up the wall
cost was $73 auzzie with postage
2017 Golf Alltrack 135tdi All options
Easier solution - Polo 6C GTI: How to Disable Engine Start/Stop - YouTube - it works the same for Golf 7
hmm..........nothing wrong with Kufatec unit, but cheaper solution, without needing to use a diagnostic cable and without the "tell" that appears on the MFD when the car stops (i.e. the dreaded "A" with a slash) HERE
I've been using mine for 2 x years now - never missed once - every time I switch-on the ignition, the SS Auto-kill switch turns off Start Stop and I can re-engage it easily at any time in my journey by simply pressing the SS witch on the console (not that I have ever done this - I reckon SS is the most dangerous thing in the car!)
Don
PS: For those that have an earlier model mk7, the "Voltage method" shown in SloAU video won't be available - instead \, you will need to use the "temperature method" - see HEREPlease don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
Originally posted by DV52 View Posthmm..........nothing wrong with Kufatec unit, but cheaper solution, without needing to use a diagnostic cable and without the "tell" that appears on the MFD when the car stops (i.e. the dreaded "A" with a slash) HERE
Don
PS: For those that have an earlier model mk7, the "Voltage method" shown in SloAU video won't be available - instead \, you will need to use the "temperature method" - see HERE2017 Golf Alltrack 135tdi All options
Originally posted by Kachingg View PostUuuhh i fail to see how that is in any way easier? yes i have the vry small a with a slash pop up but it also took less than 30sec of my time ok it cost 70 bucks(cost saving over your method if you add in hrs minimal) but it is also reversible in the same amount of time, is your hard wired mod that easy?
DonPlease don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
Originally posted by Eaglehawk View PostSome people just don't appreciate good engineering when they see it
(I love your solution, it's the way the car should have been made!) - But I'm sure some stupid ADR rule made it "illegal". (fuel consumption?)
Oh dont get me wrong i appreciate what he has done i would not be able to that at all (blessed with 10 thumbs)
It's just that i dispute the easier part taking apart console and soldering bits into the wiring is imo not easier or quicker than a 15 to 30 sec plug and play system... even if i have to live with the vry small a with slash (which i do not even notice on digital dash unless i look for it)
Also if necessary i can undo change in same time for any dealer related warranty issues ect then reinstall after so yeah i like my solution better does not make the complex system bad i am impressed with it and the knowhow that has gone into it but its not for meLast edited by Kachingg; 09-08-2017, 04:40 PM.2017 Golf Alltrack 135tdi All options
Update on the kufatech module
Took car to dealer for 1000km check up took me about 1 min to enable start/stop and another 1 min to get rid of it again when home again
Highly recommend this item works like a charm2017 Golf Alltrack 135tdi All options
