Mk7 Golf R Discussion Thread
This is a sticky topic.
  • No this is the oil cooler for the engine oil. Mine is a manual. Thanks anyway.
    2015 Golf R. Lapiz Blue.
    • Anyone had a tap tap feeling through the floor at low speeds. It's like a stone was in the tyre tread but it's not. I noticed it between 20-50km/hr. The passenger can feel it too.
      Can't seem to pinpoint what it is. Seems more noticeable when the vehicle is cold.
      Sent from my SM-N950F using Tapatalk
      • Anyone on here know if the current/new MY19 7.5 R WAGON has active rear mufflers?
        I have searched enormously the forum and the R threads but cannot find the answer.
        I would swear that when i poked my head under the rear of the two demos I drove they had the active valved mufflers but I cannot be sure my memory is accurate nor can i find out the answer online elsewhere either, in other forums or images posted etc.
        I know the first R wagons had fake quad outlets where only two of the pipes actually worked, not sure if they were the Wolfsburgs, and later models maybe 7.5, brought real quad outlets that were all operational. But not sure about active mufflers at all.
        Info from recent new owners of R wagons welcome!
        edit: checked a my18 7.5 out the other night at a dealer and it has 4 working pipes at the back. Unsure if my19 will bring any change.
        • I'd be surprised if they did change to active (valved) mufflers on the MY19 R wagons. These days VW seem to moving towards more and more de-contenting to save money, not adding extra (more costly) hardware.
          • Originally posted by GolfRWag View Post
            Golf R's have valves that open and close depending on the mode selected.
            I'm certain this won't be removed as it makes the sound of the car more throaty.
            I've also never read about mk7's only having quads for show however know that my18's are using them
            • Originally posted by Grugly View Post
              Sedans yeah, definitely valved. Early 7 R wagons had fake second tips per rear muffler, later R wagon have true quad tips all functional, just unsure about whether latest wagons get valves on 2 outlets, I'm thinking not.
              What I have read is that the wagons get a pretty gutsy sounding system as stock so I'll see how it flies once run in. There is always the resonator delete mod, but cabin boom has been an issue for some. Hopefully the BCS pipe maybe an option if Nigel gets it sorted next year if more exhaust bark is wanted!
                I tested both the hatch and the wagon and must admit the wagon did sound better during test drives.. I also felt I was able to get more DSG farts with the wagon for some reason..
                Ended up in the hatch but am still 100% happy
                • Thanks Grugly - I have only tested the wagons and I agree it sounded good in Race etc, just enough hooligan and nice fart-pops as you say.
                  Made me think it was valved but the noise must be achieved via the tune which is impressive.
                  • I concur, I understood wagons were not valved i.e. they were effectively in an open position at all times. Combined with the larger open space out back I think it all contributed to a touch more 'theatre' on the wagon, although the R/S3 is deliberately designed to be relatively restrained to some of the competition.
                    I have not been in an R besides my departed 7.5 wagon in a very long time so would not be in a position to compare though.
                    • My R wagon doesn't have any valves on the exhaust, and all 4 tips are open all the time. I have noticed that as I got a few more Kms up (currently 8,000 odd) the exhaust has grown slightly louder and more mechanical sounding when I rev it out. Still not at all what you would call LOUD, but I think it is an improvement. Note I have the soundaktor turned off completely, so I do't get any fake sounds.
                      • This all sounds pretty positive, thanks for your thoughts people. Can't wait to actually get the new car, bloody boat hasn't moved from Freo in 5 days......
                        • Me again, sorry if this Q has been dealt with elsewhere but I have done a fair of searching first:
                          Does the Mk 7/7.5 R engines (and even other related TFSI engines) need a catch can, or air/oil seperator (AOS in other words)?
                          Or is the stock valve cover/PCV set up good or even adequate to keep most oil out of the turbo, intercooler and inlet system?
                          • Some people believe it is needed, others don't. If you are going to track your car it is often recommended. In almost all modern VAG engines there will be some oil in the inlet side of your engine, opinions vary as to whether it is excessive and will cause problems or not.
                            • Originally posted by gregozedobe View Post
                              I'm glad the exhaust topic came up. In the hatch, are both valves opened full time simply by selecting "race" engine sound in Individual mode, or does that just enact the Soundaktor ?
                              2017 - Golf R 7.5 - Blue - DSG - Proper Roof - DAP - Res' delete - Dynaudio delete
                              2008 - Mazda 2 - (Maybe my first child scared me a bit) -1998 - Wrx (modded up to but not including forged pistons)
                              1988 - Corolla TwinCam - (couldn't insure a 323 Turbo)
                              1967 - Tonka Tip Truck - Red with 2 inch plastic rims and a massive sand scoop.
