Originally posted by tonymy01
View Post
Mk7 Golf R Discussion Thread
This is a sticky topic.
Uhm owner manual says for the first 1500km, don't rev within 2/3rd of redline in each gear and don't sit on constant speed....
I was told by the service team at the dealership that it has a "running in" oil from new in the engine and this will be changed at the first service to a "bedding in" oil, he said once 1500km has been done the engine is fine to drive however you like due to the fact that the rev limiter is extremely low for how good the engine is.
Am calling up vwa today to see when and if I can get the turbo recalled and will update results on that today.2014 Limestone Grey Mk7 Golf R
DSG, Leather, Drive assist.
APR Carbonio Intake // APR Boost tap // APR Stage 1
How many times has this question been asked? Refer to your owner's manual. Whatever advice is given by other forum members, which is different to what's stated in the manual, will be at your own risk or detriment.Originally posted by jonoz View PostOn the note of running in, is there a run-in that needs to be done in the R? Or foot to the floor from dealer delivery?
Hainsy, follow the manual and you can't go wrong. I would add wait until motor oil is up to temp (95-105) before giving it the beans
Avoid cruise control over long distances during the run in period.
Hey Mikey, when is your manual R due? (Might well be on my boat due in to Melb late Sept?)
Haha yeah I definitely didn't give it any on the way home above 3k so it should be fine and was constantly speeding up to 110 and back to 100 then 90 on the freeway most of the way back until the car clicked over 1500km
Oil on the gauge sits comfortably at 90 but when you look it up on the MFD it sits around 104 degrees, really makes me wonder how accurate that gauge on the tacho is or if it is stuck on 90, but I highly doubt it2014 Limestone Grey Mk7 Golf R
Whats the go with the turbo recall?Originally posted by hainsey View PostAm calling up vwa today to see when and if I can get the turbo recalled and will update results on that today.
Just asking opinions, at the end of the day it is the owner's decision to do whatever they want but I was more curious as to any other precautions that people may take beyond what is stated in the manual. Also, apologies my R only gets to the port on Friday so I don't have an owner's manualOriginally posted by Mikey1 View PostHow many times has this question been asked? Refer to your owner's manual. Whatever advice is given by other forum members, which is different to what's stated in the manual, will be at your own risk or detriment.
Isn't that the coolant temperature guage?Originally posted by hainsey View PostOil on the gauge sits comfortably at 90 but when you look it up on the MFD it sits around 104 degrees, really makes me wonder how accurate that gauge on the tacho is or if it is stuck on 90, but I highly doubt it
The gauge is the water temp, the MFD is the oil temp. The water will sit at 90, it is temperature regulated to get it there as fast as possible from cold and to keep it there once 90 is reached.Originally posted by hainsey View PostOil on the gauge sits comfortably at 90 but when you look it up on the MFD it sits around 104 degrees, really makes me wonder how accurate that gauge on the tacho is or if it is stuck on 90, but I highly doubt it
I believe that might be the case, however, using the shipping/VIN tool, to date, "No records found". Therefore, it appears my original ETA estimate will miss end of September and be more likely an October arrival, which isn't necesarily a bad thing, as the warmer weather can only help shift my old chariot with a sunroof. [emoji4]Originally posted by andrew7 View PostHey Mikey, when is your manual R due? (Might well be on my boat due in to Melb late Sept?)
[QUOTE=jonoz;1078658]
[Just asking opinions]
andrew7 already gave sound reply I will just add my 2 cents.
Doesn't matter how old is the engine, never go into high revs until engine oil is at operating temperature. Round gauge on the dash is for coolant temp, it will show 90 degrees after about 3 km on the open road. That does not mean that engine is warm and you can give it a go.
Oil temperature is shown on the MFD only and it will take about 20 km on the open road to reach 90 degrees or higher. At this point engine and gearbox are at normal operating temperature and you can go WOT.
Cool this is the info I was really looking for.Originally posted by i286 View PostOil temperature is shown on the MFD only and it will take about 20 km on the open road to reach 90 degrees or higher. At this point engine and gearbox are at normal operating temperature and you can go WOT.
It being my/our first new performance car I don't want myself or my partner to be reckless.
Yeah I hadn't had the chance yet to look into the difference in the gauges so yeah, good to know, cheers guys
I barely give the car any berries, probably gone wot once or twice since owning it....2014 Limestone Grey Mk7 Golf R
[QUOTE=i286;1078690]It seems quite a long time that it takes about 20 km for the engine oil to reach normal operating temperature on the open road, considering the engine coolant is at normal operating temperature after just 3 km, and must provide some assistance in warming the engine oil. Of course, ambient air temperature must be a factor, but still our weather conditions in most parts of Victoria in winter are not frigid.Originally posted by jonoz View PostRound gauge on the dash is for coolant temp, it will show 90 degrees after about 3 km on the open road. That does not mean that engine is warm and you can give it a go.
