Golf R and P Plates
In Victoria the R is a probationary prohibited vehicle at 143KW/ton exceeding the 130KW/ton threshold.
I will probably be buying an R and it may very occasionally be handy for my P plater daughter to drive it, so I checked the rules.
Probationary Prohibited vehicle
A vehicle that:
has a power to mass ratio of greater than 130 kilowatts per tonne, or
has an engine that has been modified to increase performance (other than a modification made by the manufacturer in the course of the manufacture of the vehicle).
Got me thinking the R's power output needs to be reduced from 206KW to 186KW for it to comply.
So lets say I get a switchable stage 1 tune when it becomes available that includes a "valet" program that reduces power to < 186kw or something less along with a certificate to say so.
Then with regard to the dual criteria:
1) My R will have a power to mass ratio less than 130 kw per ton. Check.
2) The engine has been specifically modified to decrease performance and the power to mass ratio to less than 130 kilowatts per tonne. Check.
So long as appropriate tune is in effect when she drives it then all is good. whaddyareckon??
A vehicle that:
