Mikey1 that is what I get in my Tsi Highline. It will take almost 10 km for oil temp to reach 50 degrees and to show on the MFD. Freeway I use is flat and straight and doing 110 kmh in 7th gear engine sits on 2100-2200 rpm.
I read somewhere, years ago, when I was about to do my first Atf change, to get the Atf to operating temp it takes about 16 km of driving.
Apparently mk7 has quite complex cooling system in order to achieve emissions target and reduced fuel consumption as well as occupants comfort. In the first few minutes coolant circulates only through the head and the heather core. That could explain why we see temperature gauge showing normal operating temp quite quickly. I will try to find that info if I can.
Don't think that ambient temperature had significant influence in my findings. Will try to get accurate numbers for winter and summer period.
