Hi guys, I have a 2013 mk7 tsi and wondering what brake pads to get. I need replacement fronts, it's only for street use and I drive like a grandma. Just looking for something that will last long and gives off not alot of brake dust. I had remsa's before but it's hard to find them now.
ATE Ceramic pads. I got a quote for my 2018 golf with ATE ceramic pads and ATE high carbon steel rotors for the front for $895. same setup for rears was $650
2015 Carnival Yellow Honda S660
2023 MY23 Nevada White Cupra Formentor VZx
2024 MY23.5 Moon White Skoda Scala 110TSI Signature
As above, the ATE ceramics are very good but also quite expensive. I have used the Brembo ceramics on a few cars recently (including my own car) with excellent results and they are cheaper than the ATE's too. Same characteristics as the ATE's but cheaper. These should be the correct pads for your car (the Remsa equivalent part number is 151501 Link to Brembo brake pads for Mk7 TSI
Saw this rather old post. I'm due for my first pads (all 4) but car only done 40k (which for city driving and still the originals I guess is ok). what is of concern is the mechanic said that especially the rears, the discs need replacing as with these sorts of cars, machining them is not a good idea. I do trust this guy as I have had him for many years and always does a good job with all my vehicles. The disk is considerably worn with a nice 2 ish mm rim now.
these ceramics you talk about.... do you need to also change the discs or can the normal discs work fine. And also how much longer do they last. (twice? 3 times? a 10k more)
But am interested before I commit to changing all 4 wheels with new discs and pads.
The factory pads have a high metallic content, hence why they wear very quickly and leave your wheels covered in horrible black brake dust. They provide good braking performance but absolutely chew through the pads and disks.
Sounds like you need new disks - disks are so cheap these days that it make not sense to machine them plus machining is only really done for light wear and light warping - not for heavy wear like what you are describing. if you replace them with VW parts then you will have the same scenario in another 40,000km's time.
The ceramic pads are much more gentle on the disks. Id confidently say they will last twice as long as the factory pads in my opinion. You will want to install the ceramic pads with new disks - but you don't need special disks - whatever brand you want to use is fine. Id recommend the Brembo disks and pads as a well priced option, I have fitted several sets of the Brembo's to my own car as well as family members cars and they are great.
