  • Originally posted by nickows View Post
    My AC is very noisy. There is almost always a constant hissing noise when the AC is turned on. The hissing is noticable even when driving up to 60-70km/h. It disappears as soon as you turn the AC off (with the fan still running).
    And the gradation between different temperature settings feels non-existent. 25 degrees feels just as cold as 18 degrees. I normally set the AC to a higher temperature (24-25 degrees) but it's still freezing.
    Anyone else experiencing this?
    Hi Nick, don't notice any hissing from mine and in the 40 ish degree days we had in Perth recently the temp difference between 25 or 18 was significantly noticably. Also when on moderate days you can notice the temp changes and on lowest fan setting no noises except the fan motor. I'd say you may have a problem, aside from that you enjoying the R? I still love mine after 2 and bit years and 40,000 kms
    Chris
    WLF127
    • Originally posted by Ideo View Post
      I remember back in the day when it was seen as amazing to have a 3 speed fan. Now we are complaining about how little difference there is in the temp we can set in one section of the car.
      It's an observation, not a complaint. I haven't experienced this AC hissing noise in previous cars, and interested to hear some constructive feedback from others if they are experiencing something similar. Isn't that the point of this thread?
      If it's a loud hiss then maybe a vacuum line has come off an actuator or one of the flaps isn't closing properly - hence no discernable difference in AC temp.
      Thanks for your helpful reply. I'll check it out and mention it when the car goes in for service.
      • Can't we all just get along?
        Wait a minute, this is vwwatercooled.
        Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
        • Speaking of AC, I noticed today when trying to look around a truck (moved head closer to window) that the AC doesn't cool down the car, as I immediately felt warmer. Only when the air is hitting me do I feel cool. Which explains why when I turn it off the car feels hot so quickly. Not sure if that's a problem or not.
          Audi A3
          • Golf R Observations and Questions
            Does boost get pulled down in hot weather ?
            I know power will be down due to hot air but what about boost ?
            Edit - never mind, it does, 49C has an impact
            All good.
            • Originally posted by Ryan_R View Post
              I recommend white paint and dark tint =
              • Originally posted by Machine View Post
                Works for me !
                Car outside the service dept for a few hours in 49C temps and remarkably "cool" in the car when I picked it up
                  You're just describing my old car
                  Audi A3
                    Originally posted by Candyman View Post
                    Works for me !
                    Hope they didn't leave it idling with the air on for a few hours
                      Engine cold so don't see how unless yours is magical ?
                      Edit - so nice to be back to "normal" temps. Car happier.
                      • Originally posted by brimway View Post
                        Why not? My wife idled our Nissan with AC on for 7 hours when the roads North & South of her were closed due to bushfires. It used 9 litres of fuel IIRC. Better than her & the 2 kids getting heat stroke.
                        • Uploaded a GT5 video with the Golf R
                          Audi A3
                            Agree about it dealing with heat stroke but generally "bad" for a car to DIY idling for hours
                            Sometimes you gave no options but parked at a dealers, no thanks.
                            • Originally posted by Candyman View Post
                              No magic here, if it was 49c ambient, mine would be like a sauna inside.
                                I did say "cool", not cool
                                All relative, but yep, did surprise me it wasn't much much hotter inside.
                                Have a photo of the MFD showing 49 C (might be a few degrees off but have always found it pretty spot on)
                                Wife's car showed 53C on her in-car display as she drove on Windsor Road, but it is a Ford so who knows
