With ya Corey, though you have to admit a stock XR5 taking a modded R this way is hard to swallow
Golf R Observations and Questions
Thanks Corey.Originally posted by Corey_R View PostYou'll find that answered in the tuning forum, but Stage 2 isn't about huge increases in peak power over stage 1, it's about optimising what you have and widening the torque and power bands.
But directly related to the R vs XR5, it's been shown again and again that the R's advantage is in the 0 to xKm runs and not around necessarily around a track (at least in the dry). In rolling acceleration, a GTI with the same power runs away...
Perhaps it was the perspective the video? As silverfox said, it's a tad hard to swallow that a stage 2 R can barely keep up with a stock XR5
I always thought the XR5 competed against the GTI, and the RS Focus was compared to the Golf R. I once followed an XR5 down the Reefton Spur and had no problems keeping up (different conditions, driver, and all that jazz, though).
At the same time we've got other members who have been overtaking Porsche 911's and Ferrari F430's etc.Originally posted by Large Fruit View PostThanks Corey.
Does this by extension make a stock XR5 quicker than a Ferrari F430? Of course not.....
There are lots of variables in these things, and no one knows truly what they except for the driver of each of those cars (and even then, they might not be aware of all the variables
Given a can't see the vid, was he close by coming onto the straight? Maybe ran a **** line out of the last turn onto the straight as well losing speed overall. Curious to know top speed before turn 1 as well Big Dave, if you managed to read it?
Haven't looked in the tuning section yet but I guess a Stage 2 is ~200kwatw?Golf R - 77TSI engine transplant, 91ron tune, & a crochet rug on the parcel shelf
Yep. Too many variables to really call.Originally posted by Corey_R View PostAt the same time we've got other members who have been overtaking Porsche 911's and Ferrari F430's etc.
XR5 driver may nailed the last corner and got it perfect whereas Dave may have been baulked by a slower car etc etcAudi S3. Sold
Golf R. Sold
Citroen DS3 Dsport. Sold
2016 Skoda Octavia RS Wagon.
And stock/stage 1's do around 98-100mph?Originally posted by adzy View PostStage 2 Golf R's do 101 - 103MPH
Last week at Sandown, Fab (who ran 106mph?) would pull away from me on the straights and that was with him not going really hard given I was able to get back near him under brakes and cornering.
If an XR5 is nearly 10mph down on a stage 2 R, something is wrong....or maybe it's accurate and the product is more marketing fluff than substance.....
A couple of questions then.
What is different between the GTi motor & the R donk? I see the compression is slightly more and heard something about a steel timing chain??? Is the bottom end the same?
Also has anyone been able to log the torque split with the haldex unit thru various situations? I read somewhere it can split up to 100% rear which is good
Pity there is no manual overide to lock in what you want, but anyway...What ratio is straight line for instance at a constant 100km for example.
Also regarding oil changes has anyone bothered to do a 6 monthly change themselves?
Cheers PaulGolf R - 77TSI engine transplant, 91ron tune, & a crochet rug on the parcel shelf
It's all to the front if there's no slip detected/no output from the stability control, that's how I understand it.
EDIT
Not quite zero to the rear. Cut from the Wiki:
The XWD system can transmit 100 percent of available torque to either the front or rear wheels. However, for those conditions to occur one end of the vehicle would have to lose all traction, like driving on ice for instance. During a standing start the rear wheels are put to use, without the need for any slip to occur. Then under straight-line cruising conditions, to conserve fuel and driveline wear, the torque split to the rear wheels is reduced to a level between 5 and 10 percent. Also up to 85 percent of torque can be transferred by the eLSD between to any single rear wheel if necessary. The system can adjust torque splits based on calculated conditions, such as those that indicate an aggressive lane change manoeuvre, to effectively reduce oversteer or understeer without any wheel slip occurring. In the event that some wheel slip does actually get to occur, the system can react more timely and efficiently than in the past. [6]Last edited by h100vw; 24-09-2011, 11:15 AM.
Haldex Traction - Wikipedia, the free encyclopedia
Have read of the whole wiki. SAAB had first dibs on it for the first year.
