Before I got my car, I setup the wheel on my gaming PC to also be the wrong way around so I could practice without too many ill effects. I stuffed it up plenty of times, but I'm pretty decent with it now (as long as I'm not focussing too much on the actual driving on twisty roads, where I just use Sport mode). Since my car can do 70kph in 2nd or 7th gear, it's usually not the end of the world if I get it wrong now and then
Now if you're really clever, you'll forget that you've gone from Manual mode back to D and then change up into Neutral! I would've liked to think you'd need to press the button in to switch into neutral.
The only other thing that sometimes catches me out is when I start the car, select D, and wonder why the MFD shows 'N' (for North)
