Dude - there was only 1.6 seconds between the Golf R and Golf GTI in the Motor Tuner Challenge. The Golf R beat EVERYTHING, including Porsche GT3s and Lotuses etc. The fact that on an obviously extremely wet track the GTI with its FWD managed to get within 1.6 seconds is absolutely awesome.
I know you own the GTI and like to justify your purchase of it, but seroiusly...
It was an interesting read mainly about the affects of different sway bar settings.. Just like having your car fully slammed doesn't equal better handling.
The times are pretty close all things considered and on a wet track.
H&R sway bars -v- APR sway bars : Both set up for max attack!
Looking at the MOTOR Magazine ‘Castrol Hot Tuner’ stats between the Golf R and Golf GTI confirms that I made the correct decision in sticking with the GTI. 400m V-Max and Eastern Creek V-Max has the GTI ahead of the Golf R. In other words, the GTI starts off slower from standstill or corner exit and trounces the Golf R down the straight for a higher end top speed. The big plus being the new tech EA888 motor in the GTI in either stock tune or right way up to full house stage III tune. Hell … the driver at the end of the Golf GTI YouTube video says without EDL/XDS interference, there could be another 4-5 secs to shave off the GTI’s lap time. Crikey!
The point I was making in the former post was that the Golf R tuned with the H&R sway bars was a better set-up for Eastern Creek Raceway in the wet conditions. Same applied to the rear wheel drive BMW 135i Evolve also fitted with H&R sway bars, which also posted a fabulous lap time and only 0.4 sec slower than the AWD Golf R. The APR (aka Hotchkis) sway bars set on maximum attack on the Golf GTI compromised it more so than the Golf R or BMW running H&R sway bars. Both GTI and Golf R were running the same brand of coilover suspension.
The lift off oversteer tendencies depicted in the Golf R YouTube video could sometimes occur on my old MKV Golf GTI fitted with KW V3 coilovers and small size H&R bars set up for neutral handling chassis tune (front soft/rear hard) – this state of tune could be unnerving when lift-off oversteer occurred unexpectedly on approach to the apex with some trail braking – esp. on downhill corners on public roadways. This was not so much a problem with the softer Eibach ProKit Strut Springs & Koni FSD that would lean heavily on it outside front tyre due to less spring rate of the Strut Eibach Spring. In the end, I opted to pull out the KW V3 and fit HPA Motor Sport KW SHS coilovers to re-introduce some added fun and most importantly - compliance – as it was a daily street driven MKV GTI and required additional time from grip to slip in adverse weather conditions or on rougher roadways.
Maximum spring rate, in either springs or sway bar rate, is not always a good thing when considering varied roadways and weather conditions – the YouTube video clearly shows this to be the case with both Golf R and Golf GTI. Other makes of vehicles also suffered from too firm sway bars – Subaru Liberty GT with street tyres and one of the Falcons with firm rear sway bars that caused it to lose compliance and slip into over steer too soon. Not necessary a good thing to have on a wet bumpy back public roadway imo.
The YouTube videos are great in that they show what I’ve been describing in past WJ Suspension Reviews in terms of lift off oversteer. Suspension tuning is an art in itself. I think Paul Morris did a reasonable job given the chassis set up of the two Golf’s and wet conditions - as he’s trying to drive around the idiosyncrasies of a dry track setup. The owner of the Audi S3 by Peak Performance also indicates that Luff had issues with lift off oversteer – the Audi S3 also ran H&R sway bars set for a neutral chassis tune (soft front/rear hard).
good write up.
i'm in the same boat.
chipped mkv gti (the wifes) and now a golf r (replacing my ve ss).
how you have described both is perfect!
Seems like a few people in similar boat! We have a APR stg 1 MkV GTI and about (90% sure) to replace my Polo GTI with a Golf R. I think everyone seems to notice the same things about the R. More lag, better handling etc
I think the only doubt i have in my mind about the R is the fact that suspension is so much stiffer, dont get me wrong, its awesome. Feels tight as a drum but those bumps are pretty harsh. Exhaust sound is a lot nicer than the MkV GTI.
What to do?!!
1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
What to do?!!
I wouldn't be concerned about the Golf R's suspension coming from the Polo GTI, especially if you option the ACC.
Although both cars have firm suspension, the Polo GTI is very unforgiving of speed humps etc (even at 15kph), whereas the R is much more absorbing. Your $30k difference does go to good use
Sorry mate, in this case, you are totally wrong about the setup & handling on the R & GTI for the tuner shootout.
One GIANT factor you did not put into your equation was tyre choice & pressure.
Both the GTI & R in the standing water had large understeer problems, and lift off oversteer is difficult in both cars because of the amount of rear end grip generated by out Superlap tyres.
In our initial (and only) pre event testing at Lakeside with the new rubber, we had difficulty getting the rear to "turn" with lift off due to the mechanical grip available. This made the understeer actually "worse" and on the GTI, this is further complicated by our front differential settings. We had this on a "soft" setting, which is great for street & track, but killed us in the Motorkhana in the magazine test.
The H&R bars on the Golf R are way too soft for the track, and this is why the R is not a lot quicker than the GTI - It should be seconds & seconds faster.
Take it from me, I have done over 120 combined track laps in both cars at Morgan Park, QR & Lakeside.
The GTI shines with its lighter weight, the motorsport differential gets it out of corners so well, its almost AWD fast (in the dry).
Simply at the Eastern Creek event with standing water, there was no lift off oversteer intentionally induced on either car - if you watch the other footage of the other vehicles, its a combination of aquaplaning & all wheel drifting.
I think the top end speed differential is also a lot to do with the gearing (as well as the weight difference)- here is a question for you:
GTI & R at lakeside (fastest average speed track in Australia), same day, same driver, same terminal main straight speed (212kmph)
Certainly agree with you on all the factors mentioned above in terms adjustments affecting chassis tune, esp. maxium attack settings for the dry weather on semi-slick tyres.
I can only comment on what I see in the two YouTube videos at Eastern Creek. Here's the video of the Lotus:
Where do you see the Lotus fall into lift off oversteer on approach to apex? You don't. At no time does the driver have to make opposite lock correctlive steering adjustments on power 'off' or trailing throttle when entering any corner at EC. It can clearly been seen from the driver's steering and throttle inputs and body language in the Lotus - The Lotus only oversteers only on power down, which is understandable given its turbo 4 cyl 500hp motor. Very sledom does this very light Lotus aquaplane and it's easy to drive, flowing from corner to corner with slight to moderate understeer on corner entry - look at the angle of the steering wheel when driving into and out of corners.
In contrast:
Look at the body language of the GTI on corner entry when Morris is 'off' the throttle on corner entry - the rear end nervously kicks out with the driver having to apply opposite lock to correct the slide in the rear end. When 'on' the power, the GTI is not oversteering or aquaplaning in the video. The GTI appeared to be very nervous in rear end with a lot of lift over steer generated only on corner entry - The Golf R had similar characteristics, but not the same degree as the GTI. The GTI is lighter in the rear end and has plenty of rear sway bar spring rate excerbating the lift off oversteer imo - aside from all the other factors mentioned. The GTI is heavier than the Lotus that did not exhibit any aquaplaning in the YouTube video imo. The Golf R did not power oversteer when on the power out of corners as in the case of the GTI. They both slide into oversteer on almost every corner entry in the videos.
If both Golf R and GTI run same tyres, same coilovers, same adjustments to tyre pressure, same suspension bushes - then it must be the sway bars making most of the difference - or course: lighter rear end of the GTI excepted when turning into the corner.
In contrast:
Cheers.
WJ
If the Lotus is so good,why was it shedload slower than the Golfs?????
And if it handled so much better,and was easier to drive,why did Paul spin it?
You can have all the same settings on both Golfs,but I don't know if you've noticed,but one is two wheel drive with a LSD,the other is 4wd Haldex.
Kinda makes them a bit different....
WJ, I appreciate you trying to draw conclusions from internal camera footage on youtube, but if it was that easy, then there would be thousands of chassis engineers out of business around the world.
If you had of attended the event in person & witnessed Mustangs, Camaro's, C63's & 600 HP commodores & Falcons having massive understeer, you might have a little more understanding.
Sway bars probably had the least effect in overall suspension setup for the event. Personally (as mentioned above) tyre choice & pressure was #1, I think you would have seen the exact same track footage if we disconnected the swaybars on each end.
Simply put, standing water & aqua planing are the two factors you continue to forget, the video might not show them clearly enough for you - that was the number one problem.
End of the day, the Golf R & GTI finished pretty similar in times to what we have seen in the dry, both are totally neutral in cornering (when set for tyre type & track type) = both are very easy to drive close to their limit with the underlying ESP turned on.
Once again, put on second rate tyres, and have radical suspension & wheel alignment settings, it all changes again.
P.S. I think you will find in the next magazine that the 2 x Golf's may have been faster than the superb Lotus that you comment on.
you will be able to compare lap times when the next magazine comes out!
Guy,
ESP has been criticised for 'track' use because it overrides driver intended car slide/trim/attitude, call it what you will.
Did ESP influence lap times; if so, how?
Was ESP functioning in your cars?
What are the prospects of tuneable or a true 'off' setting for ESP either through you or other developers?
Can you pull the plug on ESP beyond the switch? Does it run on its' own electronics ccrt or are a number of systems co-powered? If so what are they? Does software have a diagnostic to detect disabled ESP and override freedoms?
Did you have any Haldex modifications on the R; I haven't noticed any discussion WRT Haldex tuning.
Pete Shelley has described his Stage 3 S3 in very 'tyre smoking type colourful' terms - I didn't ask him at the time about how ESP allows such antics.
On a dry surface, more significantly, would the increased rear bias offered by a Haldex controller improve power down or other drive characteristics, eg mid corner understeer? Or are you managing chassis balance through wheel alignment/suspension setting?
It seems the extremely wet conditions of the day really undermined the value of the Hot Tuner shootout? Pity logistics of such a big event are what they are.
In the table on the shoutout writeup, you will notice that the "Diff" is mentioned twice for the R. The cost is $1950, which is the price of the Gen IV Haldex controller. So I've assumed all along that the car has it installed.
Whilst i'm not a fan of ESP, (i think a well placed right foot will result in better times)
I can't help but think about the performance gains of the XDL setup.
Braking the inside wheel in a corner is not something that a driver could replicate,
Assuming VW have done it properly, surely it would bebeneficial to lap times if this component was left active?
2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
Hey Ethosguy - have to excuse me, I'm on my first weeks holiday in along time, so have to reply in between fishing trips!
Anyway, yes, the ESP can be manipulated at different levels, the MK6 has two levels, the second is the one that contains the XDL differential which can not be "switched off" & draws criticism from drivers & journalists on the track.
In this challenge it was a tough call what to do because of the weather, anyway, we decided to leave it "factory" and Paul thought he could have shaved a further 4 - 5 seconds off the time. Anyway, there was no opportunity to test different settings on cars, one setting had to do the event.
Unfortunately the legal implications of manipulating the ESP is an issue for cars driven on the street is an issue that cant be sorted at the moment.
B.u.g.g.e.r! Oh, wrong forum...
There might be something between the lines there?
Sounds like you should leave the net at work. Have a good holiday.
