Originally posted by REXman
									View Post
Golf R -v- Golf GTI
Maybe, in part, the MkVI worked better in the wet because you didn't have stiffer upgraded suspension?Originally posted by WhiteJames View PostIn terms of understeer bias ... the MKV GTI and the new Golf R offer a similar chassis tune. They are tuned to cause the motor vehicle to push wide off the mark when on the throttle during cornering.
...I had the pleasure of driving from Sydney to Goulburn recently in the torrential rain via the Macquarie’s Pass, up 20km of steep winding roadways, with streams and waterfalls running across the roadway in many parts. Never once did I lament not having AWD. That wasn’t the case with my previous MKV GTI, even with upgraded heavy duty premium suspension.
WJ
Stiff suspension doesn't intrinsically improve grip. Handling and grip aren’t synonymous terms: Nor are predictability and speed. Chassis tuning trades off against a variety of parameters. What comes out of VAG (and most other manufactures) is a pretty safe & predictable setup, as you rightly say, for punters like you and me. Too bad OEM tune is also tedious.
HAHA you bastard! I just had to clear a mouthful of breakfast from my monitor! Quoted for truth!Originally posted by REXman View PostThe only thing the GTI is better at is not being as good.
I went for a random hoon last night with the missus after dinner. Fwy, suburbs, twisties, basically until the yellow light came on and the car can do everything! The GTI could have probably done all the same stuff, but the R will do it better!
Even found a new Focus RS in my travels. I think he was afraid of the R's awesomeness cos he wasn't interested in doing anything unless I was behind him. PS that green is farken HIDEOUS!
You bloody hoon Dave!Originally posted by dave_r View PostHAHA you bastard! I just had to clear a mouthful of breakfast from my monitor! Quoted for truth!
Good to hear you had some fun though.
Yeah the green is horrid, seen one the other day!
Are you around the Eltham this weekend mate?
Yeah - this is a good point. When I'm watching motorsport, the first thing that the team do where possible, is start unhooking antiroll bars etc to loosen the car up. Stiff car in the rain is detrimental to its handling.Originally posted by ethosguy View PostMaybe, in part, the MkVI worked better in the wet because you didn't have stiffer upgraded suspension?
Exactly the point I was making to Fab about lowering his car. Sure it will change the handling but not necessarily for the better for its intended use.Originally posted by ethosguy View PostChassis tuning trades off against a variety of parameters.
And if people are worried about R's understeering there's plenty you can do to improve the situation even without spending any money. Try upping the rear tyre pressures or dropping the front tyre pressures relative to each other. Or if you want to spend the smallest amount of money get a stiffer rear swaybar.
Be interesting to see what happens to an ACC car if you start playing with suspension tuning whilst not changing the shocks. I wonder what parameters it monitors to control its responses.
Played with my launch control this morning, funny thing, once it went past 2000rpm the needle started dancing and wouldn't (struggling) reach 3000rpm. This wasn't the case when I used LC at VW's driver training day with their GTI.Originally posted by AdamD View PostI've read quite a few posts that suggest the ideal point for a good launch is 2400rpm with a GTI - at least a stocker. Not sure how that'd change with a stage 1 - maybe 200-400 rpm less.
						[MK6 GTI MY11 CW 3-door DSG Sunroof Detroits Dark Tint R LEDs APR Stage 1 (regrettably a few years late)]
sometimes it will do that if it didnt engage properly, with 'LC' engaged the car should sit nicely still with the brake on and hold its revs, if it doesnt hold revs, or trys to move off then its not engaged properly and you need to go through the process again. Remeber that this isn't a 'true' LC so its not by any means perfectOriginally posted by Converted View PostPlayed with my launch control this morning, funny thing, once it went past 2000rpm the needle started dancing and wouldn't (struggling) reach 3000rpm. This wasn't the case when I used LC at VW's driver training day with their GTI.
True non biased journalism this. WOW...Originally posted by WhiteJames View Post...Both MKV GTI and Golf R understeer more than Falcodores...
WJMY07 MKV GTI DSG CW 5dr Apr stg2 [gone]
MY10 MKVI Golf R Reflex Silver DSG 5dr BLUEFIN MDI (dealer fitted). [gone]
MY12 VW UP! baby blue 5dr
Expecting MY14 Audi S3 SB White S-tronic
I agree, however there was some info suggesting what methods could be adopted in reducing understeer with the R along with ACC opinions, however they seem to have been deletedOriginally posted by bcm View PostExactly the point I was making to Fab about lowering his car. Sure it will change the handling but not necessarily for the better for its intended use.
 edit: I now know why haha
At least one newly acquired R member took benefit and decided to address this car accordingly.Last edited by Capercat; 20-12-2010, 01:35 PM.
I missed that info and would like to see more. I've got the car into a bit more understeer than expected a couple times. Haven't played with tyre pressures yet but I suspect the biggest issue is the Dunlop Sport Maxx tyres fitted to the car. I had them fitted to some previous RWD cars and found them to have rubbish grip. Will probably get upto Volkspower in the new year and have a chat about some options like sway bars etc.Originally posted by Capercat View PostI agree, however there was some info suggesting what methods could be adopted in reducing understeer with the R along with ACC opinions, however they seem to have been deleted
And thinking about this thread, there isn't much an R can do that a GTI can't but they don't come in Rising Blue
