Work out under what conditions it's easiest to replicate so that you can demonstrate the faults to the service tech who will hop in the passenger seat and go for a quick drive with you to confirm the fault when you visit the dealer.
DSG: Problems, Questions, Likes and Dislikes
Putting DSG into D or R (Golf R)
Just a question, if this is normal or not:
when, for example pulling out of a carspot, and you go from P > D, or P > R, if not completely stationary, ie: slightly rolling, does the car shudder\splutter into gear ?
Im not sure if its a gearbox issue, or just how the dsg is, but i need to completely stop, engage either D or R, wait a second, and then start moving, if im in say N and just put it into D without braking, it will shudder into gear
Golf R dsg gear changes
Has anyone with a Golf R or GTI notice there car bounce off the limiter before it changes to the next gear when WOT?
Is this normal? I've notice this happen a few times in my R when in D and going from 1st to 2nd. Does the DSG tune help with this?Daniel
HIS - MY11 VW Golf R - Leather seats, Sunroof - DSG - 19" Talladegas - Black Headlights - Dynaudio - ACC - APR Stage 1 - Maniacs DSG Paddle Extension - Volant CAI -
HERS - MY13 VW Passat Alltrack - Sports Pack - Panoramic Sunroof -
Should not happen - get the workshop to investigate2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
I have heard of this issue happening with some cars, particularly those that are tuned.Originally posted by drad81 View PostHas anyone with a Golf R or GTI notice there car bounce off the limiter before it changes to the next gear when WOT?2008 MkV Volkswagen Golf R32 DSG
Both times this has happened its been going from 1st to 2nd with the steering turned. I wonder if loss of traction in the front wheels my be contributing to this.Daniel
Sounds like a recipe for traction control intervention.
Hello Fellow Dubbers
So my Trans Cooler has corroded (6 Speed tip tronic) Transfluid mixed with coolant.
Fellow member Piper26 hit me with the information 100% spot on, The Trans people reckon the clutches will all be damaged because of the water (approx. 2000km from the last trans service), Are they correct? If I install a new cooler flush the coolant system and dump the contaminated fluid and refill will fresh trans fluid, will this work or is my MK5 headed to an early grave...(Quoted $4500 for a rebuilt trans)
Regards
SG
Try the flush treatment. Transmission is fun to refill and fluid is costly. But give it a shot before buying a new transmission.
Sent from my iPad using Tapatalksigpic Camden GTI Performance. VW / AUDI Specialists
Hi,
Apologise if this has been mentioned before but I searched for an answer but no success. Was driving our 2007 V6 Passat last weekend & a fault developed with the manual/Tiptronic shift. When shifting the gears from low to high & vice versa, the gears failed to engage & the instrument counter gear shift indicators lighted up all at once. However when I shifted back to "D", it started to work/drive again. Any ideas what causing this & is this a common occurrence? Thanks, Ian
Can't say I've ever heard of that one.
Scan for fault codes and/or make a booking with the dealer.
That sounds like the beginnings of a Mechatronic failure. Definitely get the dealer to look at it, and just be prepared in case it happens again and leaves you stranded.Originally posted by ipy View PostApologise if this has been mentioned before but I searched for an answer but no success. Was driving our 2007 V6 Passat last weekend & a fault developed with the manual/Tiptronic shift. When shifting the gears from low to high & vice versa, the gears failed to engage & the instrument counter gear shift indicators lighted up all at once. However when I shifted back to "D", it started to work/drive again. Any ideas what causing this & is this a common occurrence? Thanks, Ian2008 MkV Volkswagen Golf R32 DSG
