Headlight / Headlamp Upgrades (Bi-Xenon / HID / LED / Replicas)
  • Yeah I think I'm getting my bits mixed up. New Halogens would be a great idea I agree
    New Style HID Replica Headlights - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
    I think that particular one, not being OEM, is designed that the existing halogens will fit (to a certain extent.)
    "The lights have a 10 pin harness and is designed to be used as an upgrade for halogen equipped cars. H7 bulbs fit in there with no problem. The rear cover is pre-drilled to run wiring for your HID kit. If you decide to use halogen bulbs, you can always put some duct tape or a grommet to cover up the hole."
    MY11 118TSI - sports kit/sunroof/Mdi - United Grey
    • kaktusdigital are you thinking something like this?
      Ed's Golf 6 HID Replica Headlights! - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
      GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
      • yep, Those look about right.
        Probably looking to get a set and run some bright halogens through them.
        • let me know i am considering that myself
          • Can genuine golf led headlights fit standard GTi?
            Is it easy/possible to retro fit golf GTi 35 drl/led lights onto my stock GTi?
            MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
            • Originally posted by sVWatt View Post
              If you have halogen headlights and try to swap xenon bulbs you will have issues with the eletric's/coding from what i have read.
              Happy to be corrected though.
              • I would think should be able to by the whole light assembly.... then code the MFD. Not sure thou. Good luck.
                I think the Adidas GTI has these lights as well.
                2011 MK6 GTI ED35
                APR Stage 2 / APR HPFP / APR Turbo back Exhaust / VWR Intake / Ohlins shocks / HP Sway Bars / HP Control Arms
                MY13 AMAROK HIGHLINE / Oettinger tuned / ATS Wheels
                • Just finished helping someone do a complete retro fit including self levelling and AFS sensor on rear suspension. It is a massive job. If you want to just change the light units and not have them 'move' it is not too bad. Front bumper removal required plus new wiring adapter plugs and harnesses.
                  Still need to code of course.
                  You should have done what I'll do next - tick the box that says Xenons when you bought it
                  GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
                  • it's easy (if you have done it a few times aka revising the installs to work correctly), just need about >$3k (OEM headlights + uprated BCM + AFS module / sensor / wiring harness, 10-14pins adapters, headlight washer kit, etc etc) plus plenty of time, courage, tears & joy ...
                    have a look here for a start:
                    as Ozram said above, tick the option when buying a new GTI, it's a lot easier, cheaper and a lot less headaches!
                    MINI Cooper S Clubman - FWD
                    • Luckily mine has them standard. I have seen some cheap ones on ebay, but they are very poor quality. Even the light output from the xenons and the LED's is noticably reduced. Not sure if they have the dynamic cornering function either.
                      • Originally posted by Ozram View Post
                        Yeh just read some the DIY links. So not worrying about the moving part. What is the BCM and AFS ?
                        Maybe the Mars plug and plays would be easier?
                          And I really appreciate it man!
                          .:Polo 6R 77TSI
                          .:Golf MK6 GTI
                          II Kraftwerk
                            This is a big job,
                            The Body Control Module or Central Electronic Control Module
                            The Central Electronics Control Module (CECM) is situated above the pedals on the drivers side and controls all the lights in the car, monitors them, controls what appears in the MFD under the lights menu, controls the leaving home and coming home lights function, controls the horn(s) and other features. There are different variants of this module called the Medium and the Highline, the latter is required for fog lights, bi-xenons and other features.
                            Adaptive Front Lighting System (AFS) is in charge or "auto" level the Bixenon headlights depending of the road conditions,
                            .:Polo 6R 77TSI
                            .:Golf MK6 GTI
                            II Kraftwerk
                            • Win Power LED HID Lamps
                              I'm keen on a pair of led lamps for my car, and these look good from win power...
                              2009-2012 VW Golf 6 Headlight with 15 LED DRL and Bi-xenon Projector,View Golf 6 Headlight,Winpower 2009-2012 VW Golf 6 Headlight Product Details from Guangzhou Hualuying Electronics Ltd. on Alibaba.com
                              ...anyone got experience of their quality etc?
                              • He is advertising them as xenons but hen talks about HID so I'm a little confused about what they are exactly but if they are true xenons they will be illegal on your car without pop up washers and auto levellers.
                                MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
                                MY12.5 Polo 6R GTI
