ABS causing many issues, cannot fix so far
  • ABS causing many issues, cannot fix so far
    Hello everyone, this is my first proper post outside of the Newbie section. Im mostly certain that this type of issue hasn't been discussed on this page before but I apologise if it has been. So I have a 2011 mk6 golf 103TDI, and its got an issue. It started probably a year ago ish and has slowly worsened, I am having an issue with my abs which triggers an engine fault, then the power steering, speedo, and then the fuel gauge to bounce/ move around.
    To get into the details of the issues,
    • the traction control, abs, and stability control lights come on as well as the hand brake light flashing, on the dash screen it says brakes error workshop
    • the glow plug light also flashes as well as the engine light on too
    • most of the time the steering light is on as well, indicating the power steering is out, this sometimes does go out but is getting more and more rare
    • additionally and this is the part I find most odd, the fuel gauge moves, eg. when I put my foot down, or am on a hill the gauge is in the incorrect spot and bounces around
    It initially started with the abs lights coming on rarely, and I'd power cycle the car and they would go. This progressed to them being on constantly but only going away once the engine was at temp. then power cycled, this solution did however slowly stop working and it is now at its current point as described above.
    what I've replaced,
    • all four abs sensors ( though cheap eBay ones I wanted to prove that they were not the fault, which is has been confirmed that they are not)
    • all abs, and stability control related fuses and relay
    • the multi/ central fuse on the side of the fuse box ( replaced today, did a test drive and the speedo came back only after power cycling, all other issues remain)
    • battery has been tested, grounds have been checked and abs module connections have been cleaned
    With all these issues the car still drives fine, though I have to use Waze for speed but everything else works great, engine/ dsg.
    I really appreciate any help or advice anyone has, this has slowly become an annoying and expensive issue. I really don't want my first car to die after only 2 yrs of owning it. I'm dreading that it is the module itself but I know that's the most likely cause. ( happy to post error codes and photos if thats any help)
    What are the fault codes?
    Those generation of MK60EC1 ABS modules are prone to controller failures.
      I replaced the mutli fuse (1k0937629a) based on 00668 code for term. 30 but that code still shows unfortunately
      Thanks.
      Car Scanner ELM OBD2
      DTC report
      Selected brand: Volkswagen
      ============1==============
      U0415
      Raw code: C415
      ECU: Engine control unit
      Status: Pending
      Invalid data received - anti-lock brake system (ABS) control module
      ============2==============
      01303
      Raw code: 0517
      ECU: 19. CAN Gateway
      Status: Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
      Phone Transceiver-R36; Transmitter and receiver for telephone R36
      ============3==============
      02395
      Raw code: 095B
      ECU: 09. Onboard supply control unit
      Status: Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory
      Front Right Parking Lamp-M3; Front right parking light bulb-M3
      ============4==============
      18255
      Raw code: 474F
      ECU: 02. Transmission control unit
      Status: Validated and stored in non volatile memory, Validated fault present at time of request
      P1847 Read data from the fault memory of the ABS control unit; Please read out the fault memory of the ABS control unit
      ============5==============
      16352
      Raw code: 3FE0
      ECU: 03. ABS control unit
      Status: Pending fault present during this driving cycle, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
      Control block; Control unit
      ============6==============
      00668
      Raw code: 029C
      Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory, Validated fault present at time of request
      Vehicle voltage, terminal 30; On-board voltage terminal 30
      ============7==============
      00287
      Raw code: 011F
      Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
      Rear Right Wheel Speed ​​Sensor-G44; Rear right speed sensor-G44
      ============8==============
      00290
      Raw code: 0122
      Rear Left Wheel Speed ​​Sensor-G46; Rear left speed sensor-G46; Throttle valve potentiometer-G69 signal too small
      ============9==============
      00285
      Raw code: 011D
      Front Right Wheel Speed ​​Sensor-G45; Front right speed sensor-G45
      ============10==============
      00283
      Raw code: 011B
      Front Left Wheel Speed ​​Sensor-G47; Front left speed sensor-G47
      ============11==============
      04278
      Raw code: 0010B6
      ECU: 01. Engine control unit
      Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear, Warning indicator requested
      U041500: Invalid Data Received From, Anti-Lock Brake System Control Module
      ============12==============
      13701904
      Raw code: D11310
      ECU: 08. Heater and climate[Archive (inactive)]
      Status: Confirmed
      U111300: Function limitation due to received malfunction value
      Bremsensteuergerät - bitte Fehlerspeicher auslesen
      ============13==============
      12850432
      Raw code: C41500
      ECU: 15. SRS
      Status: Test failed, Confirmed
      Communication with Vehicle Dynamics Control Module Implausible
      ============14==============
      13637376
      Raw code: D01700
      ECU: 17. Dashboard
      ============15==============
      01316
      Raw code: 0524
      ECU: 44. Power steering
      Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
      Brake control unit
      ============16==============
      00110
      Raw code: 006E
      ECU: 52. Front passenger door electronics
      Indicator repeater lamp in the exterior mirror housing on the front passenger side-L132; Front passenger side mirror indicator lamp-L132
      ============17==============
      01303
      Raw code: 0517
      ECU: 56. Head unit (MMI) (VW TP2.0)
        3 of your 4 ABS wheel speed sensors are faulty.
        Don't use cheap Chinese ones they don't work.
        Get proper Bosch or other suitable and compatible parts.
        If they are not the correct part they will physically fit, but the gap between the tone ring and hall effect sensor in the wheel speed sensor will not be correct and you'll get a fault.
        once all 4 speed sensors are working correctly and the faults don't return, you can work through any remaining faults.
          RunAutoParts sell the wheel speed sensors for Mk6 Golf. About $40-45 each for Vemu, Bosch or TRW.
          Run Auto Parts
            Just ordered a full set of PAT abs sensors, ill let you know if this fixes the problem. Thankyou.
              Hey, I took your advice and swapped all 4 abs sensors with quality parts and there has been no change so far. All codes and lights are still present, what do you recommend I do now?
              DTC report
              U0415
              Raw code: C415
              Status: Pending
              U0415
              Raw code: C415
              Status: Pending
              18255
              Raw code: 474F
              ECU: 02. Transmission control unit[Archive (inactive)]
              16352
              Raw code: 3FE0
              00287
              Raw code: 011F
              Rear Right Wheel Speed Sensor-G44; Rear right speed sensor-G44
              00290
              Raw code: 0122
              Rear Left Wheel Speed Sensor-G46; Rear left speed sensor-G46; Throttle valve potentiometer-G69 signal too small
              00285
              Raw code: 011D
              Front Right Wheel Speed Sensor-G45; Front right speed sensor-G45
              00283
              Raw code: 011B
              Front Left Wheel Speed Sensor-G47; Front left speed sensor-G47
              04278
              Raw code: 0010B6
              12850432
              Raw code: C41500
              ECU: 15. SRS
              01316
              Raw code: 0524
              Brake control unit
              U0415
              Raw code: C415
              Status: Pending
              18255
              Raw code: 474F
              16352
              Raw code: 3FE0
              00287
              Raw code: 011F
              00290
              Raw code: 0122
              00285
              Raw code: 011D
              ============18==============
              00283
              Raw code: 011B
              ============19==============
              04278
              Raw code: 0010B6
              ============20==============
              12850432
              Raw code: C41500
              ECU: 15. SRS
              ============21==============
              01316
              Raw code: 0524
              Brake control unit
                Double-check if there are any other fuses feeding the ABS, sometimes a smaller one is used for the sensors.
                Try testing the voltage at one of the sensor connectors, there should be some voltage of 5-12v with the sensor disconnected, and with the ignition on.
                The next place I would be looking is at the main ABS connector, check voltages and grounds. then check the connection between the sensors and the main connector.
                That should at least pinpoint if it's a harness issue, or the module itself.
                  First off, thanks for the advice. And secondly all sensors and connectors are perfect, with each speed sensor reading and 11.8V. I then cleaned all the sensors and connections with nothing changing afterwards.
                  I have nothing else to troubleshoot myself and I've now decided to had it off to a workshop to get an official diagnosis, then hopefully repair instead of replacement.
                  I'll update this thread once I hopefully get this issue fixed.
                    Did you happen to get this sorted?
                    I was getting this error:
                    Code:
                    1 Fault Found:
                    01130 - ABS Operation
                                008 - Implausible Signal
                    It turns out it was the ABS controller, I was still running the original problematic H35 unit. I swapped in both the controller and pump from a newer Jetta (H31) and it fixed the problem after some coding with VCDS.
                    Swapping the parts was quite simple but bleeding the new pump was NOT fun!
                    Not saying you have the same problem but let me know if you want a hand to do a VCDS scan or help troubleshoot.
                      Kieran_2 I noticed throughout your fault scan that you have this error mentioned several times "Throttle valve potentiometer-G69 signal too small"
                      This error points to an issue with the throttle body valve (or, in the case of a diesel engine, its probably blocked with soot and needs a good cleaning with carby cleaner and various brushes). You might want to have a look at this as it seems to be linked to your ABS control module issue.
                      00290
                      Raw code: 0122
