Maximum front/rear tyre width difference for 4motion?
  • #16
    you could possibly do 235/40 all round. your rear wont be legal is all. Might just have to pay someone cash and fit the rear and not take a receipt... its only a touch under what you can legally do.
    If you want to do guard work you can fit what you want really.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    • #17
      I'd be more concerned about any insurance claim, should it arise with fittings tyres and wheels that may not be legal. Even if it is legal, I would get something in writing from the insurance company, as most only require the wheel+tyre be the same rolling diameter, but only allow 1-1.5" larger width wheel based on the largest width wheel on the tyre placard
      2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
      2023 MY23 Nevada White Cupra Formentor VZx
      2015 Carnival Yellow Honda S660
      • #18
        Since it's tax return time I might get the more expensive tyre sizes and some guard work.
        I'm not too concerned with insurance. I've only got 3rd party anyway.. I prefer to self insure with the money I save on not paying full comp (and that's been a lot over the years). In the past wheel size has never really been a problem in an insurance claim from what I've seen.. While on my P's I put 17s on my dad's Nissan NX Coupe which originally had 14s. He got hit and had no problems claiming.
        If an insurance company wants to find something wrong with your car they will.
        VW Bora V6 4motion
        • #19
          Offset & wheel size Calculator here which is quite good. With the rims you have, you can fit 255/35R18 tyres all around.
          • #20
            Only problem with that calculator is isnt doesn't do stretch
            His bora is going to be fair low to fit those wheels so i doubt 255s with cut it...
            Bora gone
            Vento VR6
            MKIV GSW TDI
            7P Touareg TDI
            • #21
              Yup will need stretch. Stretching a tyre doesn't change the rolling diameter does it? I thought it only stretches the sidewalls out and the effect on rolling diameter would be negligible?
              VW Bora V6 4motion
              • #22
                does a touch, but not something worth calculating, as you said.
                Bora gone
                Vento VR6
                MKIV GSW TDI
                7P Touareg TDI
                • #23
                  Found a place that will do KU31s in 235/40/18 all round for $800 (including stretching). Price seems decent. Just trial fitted the front wheel today as I've been lazy and it's rubbing on the calliper. Looks like I need a small spacer for the 18x8.5 +30 fronts..
                  VW Bora V6 4motion
                  • #24
                    will be keen to see how u go with the spacer on the 8.5et30, thats what i currently have and am looking at putting a 5mm spacer in to trial
                    Bora gone
                    Vento VR6
                    MKIV GSW TDI
                    7P Touareg TDI
                    • #25
                      Tyre Pressures will affect it, but 225/40/18 Fronts will match quite nicely to 255/35/18 Rears
                      Rim Radius - 228.6mm
                      Sidewall 225/40 - 90mm
                      Rolling Diameter 225/40 - 2001mm
                      Sidewall 255/35 - 89mm
                      Rolling Diameter 255/35 - 1997mm
                      So Running the Rears 2psi harder than the fronts will probably resolve this...
                      Also, as there is more weight over the fronts, the rolling diameter is actually slightly smaller.
                      Good tyre size comparison site: Tire Size Calculator - tire & wheel plus sizing
                      '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
                      '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
                      '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
                      '07 Eos 2.0 TFSI - Project Eos...
                      • #26
                        I know but the problem is price and fitment under the guards. Those irregular sizes cost $100 more per corner at least, and then the rears will be hard to fit.
                        I trial fitted my rear wheels (18x10 +25) and it fits the same as the fronts.. Rubs on the calliper but also the stock strut. I don't know if once the KW coils are installed it will make it worse or better. Should be better but I haven't even opened the box yet. My mate has some cheapo 8mm spacers I will try out.
                        Also since I'm only trial fitting on one side the left and right sides of the car should be the same right??
                        VW Bora V6 4motion
                        • #27
                          are 4mo offsets different to the 2lt bangers? this is the second case of wheels no fitting. or are peoples wheels just the wrong offset...?
                          my 10s arnt as aggressive as those and i dont touch the rear strut or ever the dust cover on it.
                          Id imagine itll be worse becuase the wheel will camber in on the rear?
                          Should be the same... however mine are different by a few mm, passenger side my current setup is flush, where as the drivers side pokes a touch. but that could be put down the body damage or rear beam being off centre.
                          Bora gone
                          Vento VR6
                          MKIV GSW TDI
                          7P Touareg TDI
                          • #28
                            The 4mo has independent rear suspension same as the R32 so camber and fitting will be a little different than the FWD versions, obviously lowering will increase the camber and thus strut clearance issues.
                            Of course I could be hugely wrong but this would be my best guess.
                            2003 Bora 4Motion
                            • #29
                              yep id say your right about the rear.
                              The front would be the same setup though...?
                              Bora gone
                              Vento VR6
                              MKIV GSW TDI
                              7P Touareg TDI
                              • #30
                                I guess the front would be the same, not sure about the offset on my wheels but they are 18x8 with 225/40 on them and i have about 5 mm clearance for the fronts to the strut.
                                2003 Bora 4Motion
